Old 09-12-2017, 08:48 AM
Glo123 Glo123 is offline
Default Can Pro Tools Do Automtion Curves?
I'm having some trouble doing automation. For instance, I have an instrument playing from Kontakt and I want to automate the pitch wheel. However, I can't seem to get Pro Tools to draw curves (or even straight lines) between points. It just draws a bunch of little individual automaton points. I'm assuming there must be a way to draw in smooth automation curves?
Old 09-13-2017, 01:28 AM
ViTheVault ViTheVault is offline
Default Re: Can Pro Tools Do Automtion Curves?
Right-click on pencil tool and choose the mode you want. Set your grid. Your grid will define how your curve will be...
And I'm sure you can find a you tube tutorial...
Good luck
Sent from my SM-G900H using Tapatalk
Old 09-13-2017, 07:28 AM
Good luck
Thanks for the reply. So, when I select the straight line on the pencil tool to automate the pitch of a virtual instrument, it still creates a stepped sequence instead of a perfectly straight line. Also, the parabolic drawing tool does not seem to make any shape at all.
Also, what exactly do you mean by setting the grid? Do you mean the note interval? I've got mine at 1/4 notes.
Old 09-13-2017, 09:48 AM
Sardi Sardi is offline
So, when I select the string line on the pencil tool to automate the pitch of a virtual instrument, it still creates a stepped sequence instead of a perfectly straight line. Also, the parabolic drawing tool does not seem to make any shape at all.
Yep. That's the way it works.
It's one of the things on the MIDI side that REALLY needs to be fixed in Pro Tools. I never see much concern about it round here though. Weird.
Old 09-13-2017, 10:59 AM
Hanswurstlsepp Hanswurstlsepp is offline
I concern - but I gave up to post again and again and again and again ...
Cheers, STeff
MacPro5,1 , 32 Gig Ram, 2xATI Radeon HD 5770, OSX10.13.2  Pro Tools|HDX v2018.1.0  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 09-13-2017, 12:07 PM
lesbrunn lesbrunn is offline
Yes, one of those unbelievable things about Pro Tools.
X99 | i7 5820 | 64GB GSkill DDR4 | Nvidia GTX 950 | Samsung 950 Pro 256GB | Kingston 120GB SSD | Samsung 850 EVO 1TB | Samsung MZ7PD256HAFV-000H7 SSD 256GB | WD Black 1TB x2 | G-Drive 4TB | Audient ID14 | PT12.8.1 | Windows 10 Pro
Old 09-13-2017, 01:20 PM
Wow, I'm quite shocked that something considered an industry standard can't do this :/
I'm new to Pro Tools (as you can tell, haha), but I have never faced such a basic issue in any other DAW (Cubase, Live, etc.). Heck, I think I've even seen peoples' Fruity Loops sessions on YouTube that had such automation, haha. So weird that PT has not implemented this!
But anyways, is there a way to get the automation points to be "finer" in steps for when I try to automate things like a pitch wheel? As in, to reduce the spacing in in-between the automation points?
Thanks!
Old 09-13-2017, 03:24 PM
amagras amagras is offline
I don't know if this works but have anyone tried turning grid off?
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools 2018
andreimartinezagras.webs.com
Old 09-13-2017, 04:40 PM
KV626's Avatar
KV626 KV626 is online now
Well it's MIDI so you'll end up with steps anyway... You might not hear them but that doesn't mean they're not there.
What's important is what you actually hear. When I draw a (MIDI) line in Logic, I don't see steps, and I don't hear steps. When I draw a line in Pro Tools, I do see (sometimes tiny) steps, but I don't hear steps. Same result. Doesn't make any difference to me to be honest - in fact sometimes it's may even be a cool reminder that you're looking at MIDI information, not audio...
Mac Pro 5,1 (Mid-2012) 12-core 2.4 GHz / 40GB ram / macOS 10.12.6 / Pro Tools 2018.1 / LPX 10.4
Arturia Keylab 88 Presonus Faderport 8 MOTU 896
NI Komplete Ultimate 11 • Albion One • Soundiron Choirs • Pianoteq • Analog Lab • VSL SE/Chamber Strings • etc
Old 09-14-2017, 01:33 AM
Marsdy Marsdy is offline
Exactly. Cubase works the same way.
What I could really use is breakpoint based MIDI automation.
Dave Marsden
UK
Avid HDX1, PT12 HD, HD I/O 16x16, Avid S6 M10 24-5, 2013 12 Core Mac Pro. Robby The Robot meter bridge ornament.
Waves VEQ-4 filter curves? Benny_Cha_Cha AAX Plug-ins 4 02-19-2014 07:42 AM
Missing Write Automtion function... ukoomrann Pro Tools Software (Mac) 2 10-07-2012 06:33 AM
Learning Curves, Updates, and Pro Tools 9 tcstx Pro Tools 9 1 02-22-2011 03:35 AM
editing volume curves cc1 Pro Tools TDM Systems (Mac) 14 01-08-2008 10:18 PM
film eq curves, dvd eq curves ashish Post - Surround - Video 3 02-02-2004 06:17 AM
