Fast Track USB and Pro Tools 10
Hey all!
I've just recently moved over from using M-Powered 8 to Pro Tools 10 using an M-Audio Fast Track USB interface and I can't find a way to track with it. I've installed the drivers for it but I just can't see a way to select the input from the Fast Track. The only options I get are: interface -> Built-in microphone 1 (Mono) interface -> Built-in microphone 2 (Mono) interface -> Built-in input 1 - path n/a interface -> Built-in input 2 - path n/a My guitar sound is coming through the speakers via the Fast Track, but is unaffected by the Gain and Output dials, it is as though it is going straight through the interface to the speakers. Any advice would be greatly appreciated! Cheers. |
Re: Fast Track USB and Pro Tools 10
Is your interface selected as the playback engine in Setup/Playback Engine?
System Specs: http://duc.avid.com/member.php?u=108915 Audio Reel: http://www.wacc.net/ https://soundcloud.com/13guatamas13 |
Yes, I just checked, and the Fast Track interface is selected.
You can try adding the manually I/O in the preferences menu Setup/I/O (can't remember, not at my pc right now) also click defaul all busses under the bus tab and see if that helps
I'm not really sure how to do that. I find that menu screen quite intimidating
When I hit Track Record Enable i get a message saying "The track could not be record-enabled because it doesn't have both an active input and output assigned" |
It can be intimidating, that message is there because your interface is not setup properly.
Darryl |
Go to setup+I/O
Under Input, Output tab select default Under Bus tab select all busses in the drop down menu and the click default If this does not work: Go back to Input tab Select new path 1 mono track and name it input 1 check both boxes Click Ok and try again to record
I have installed the driver for the Fast Track, so I'm not sure why it's not showing up. If I select the Fast Track in the Playback Engine window the only options I have for input are as above (in the image). I don't get any errors when I start recording however nothing records either. I've tried all the inputs listed. Using Pro Tools Aggregate I/O I have these options: Obviously none of these worked either except for the built-in mic which captured nothing but the sound of my frustration When I used the M-Powered Pro Tools 8 the Fast Track worked fine, I'm very lost as to why this would be more difficult to setup |
Another thought comes to mind. I'm running OSX 10.8.3, should I download and install this update? Would it help my issue?
http://avid.force.com/pkb/articles/d...-3-5-Downloads |
Fast Track + Pro Tools 10 | ZachK | Pro Tools 10 | 4 | 12-02-2012 10:25 AM |
Problem with Fast Track USB and Pro Tools | TheBuk | Pro Tools M-Powered (Win) | 3 | 11-30-2012 11:55 AM |
Pro tools 8 LE and fast track Pro | Pena P | Pro Tools M-Powered (Mac) | 1 | 03-05-2012 03:40 PM |
Pro-Tools SE + Fast Track Pro!! | YuriyY | Pro Tools SE and Essential (Win) | 1 | 01-15-2012 07:19 AM |
Fast track usb and pro tools 7.3 | studio rec | Pro Tools M-Powered (Win) | 2 | 08-19-2008 10:06 AM |
