Re: 10.3.10 unstable
PT 11.0.0 and later will be able to access as much RAM as you have available.
Jonathan S. Abrams, CEA, CEV, CBNT Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10) |
OSX.
Can see what? This limitation? If you use OSX, launch Activity Monitor (/Applications/Utilities/) while Pro Tools v10.3.10 or earlier is active. In the Kind column, it will say Intel. Note that 64 bit applications are listed as Intel (64 bit).
How do I prevent these issues then? Should I set memory cache to 4GB maximum?
That seems awfully low , especially with feature film mixes where at least 5-10 gigs is needed to cache the session. When allocating a full mix session ram it seems to cache correctly in the system usage window. Do you think this is causing memory related crashes? |
The Disk Cache (kmmserver in Activity Monitor) is a separate process from Pro Tools. If the System Usage window shows that your Timeline Cached meter is 100% and your Disk Cache meter is less than 100%, then the Disk Cache setting is not the problem.
If you want the Pro Tools application to use less memory, then run as many plug-ins as you can as DSP plug-ins and set all unused tracks to inactive. If you are using virtual instruments, and those instruments can use an external memory server (i.e. Native Instruments), turn that function on, as it will reduce how much memory is used by the virtual instrument within Pro Tools.
Where exactly am I supposed to be seeing this limitation? |
You will not explicitly see the limitation in Activity Monitor. You will be able to make two observations.
There's definitely something up with 10.3.10. I've been mixing a song with 10.3.9 with no problem. Did a clean install of 10.3.10 (deleted prefs so everything was fresh) and Pro Tools kept crashing just as the song finished loading. As soon as I went back to 10.3.9 the song loaded fine. The song uses about 1gig of Real Mem according to Activity Monitor and is not pushing any of the usage limits (no VI's, CPU Native 5%, PCI 25%)
I didn't have time to load without 3rd party plugs (perhaps can try that when I have a moment), but with all those same plugs 10.3.9 works fine. All of my plugs are compatible versions and no cracks. In short: Same song, stable with 10.3.9, crashing with 10.3.10. My specs: TDM with 4 Accel cards OSX 10.6.8 (all optimizations done) Lynx Aurora 16vt PTHD interface |
Why is PT so unstable for me? | typhy | macOS | 1 | 07-31-2012 12:55 PM |
Unstable | HDK_Ent | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 27 | 03-11-2010 09:02 PM |
AAF unstable? | jackisdead | Post - Surround - Video | 2 | 08-26-2008 03:01 PM |
Why is PT 6.4.1 so unstable on OS 10.3.8..Help!. | postman56 | Pro Tools TDM Systems (Mac) | 7 | 07-07-2008 06:22 PM |
Mac? Unstable? | link | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 05-05-2000 03:57 AM |
