Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Win)
Old 01-04-2012, 01:37 AM
beatweezl beatweezl is offline
Default Add User Loops to Loop Library?
When I open the Loop Library in Pro Tools SE, there are two folders: "Factory" and "User". I can't seem to navigate to anywhere on my computer outside of the Factory folder to move my personal loops that I used in Acid into my ProTools Library. I did it manually through My Computer by moving my personal collection into the "Loops" folder but when I try to access them via Pro Tools, I can't move them into the "User" folder.
Also, in Windows, there is no folder called Factory or User. Just a Loops folder with all the categories inside.
How can I integrate my personal loops into the Pro Tools Factory Loop Library?
Thanks.
Old 01-19-2012, 01:49 PM
zegerman zegerman is offline
Default Re: Add User Loops to Loop Library?
I have the same problem, I tried to copy some midi files (drum loops) into Windows Folder (only the Factory folder exists) or subfolders, but the files don't appear in Pro Tools SE loop library.
Hope somebody can help ...
Thanks.
Old 02-08-2012, 03:45 PM
Pingafuego Pingafuego is offline
Thanks.
It worked for me, but with wave loops. I dropped my wave loops folder inside PT loops folder and they appeared in the loop window.
Old 02-22-2012, 04:13 AM
Routingwithin Routingwithin is offline
Lightbulb Re: Add User Loops to Loop Library?
I think you can only import WAV files into Pro Tools SE.
By copying it into the Loops folder found in the SE directory.
Midi files is out of the question cause it's not a sound sample like WAV.
Also be sure the WAV files are 16bit. SE does not read 32bit WAV files.
Hi-Hat & Cymbals Loop Library by Kenny Gioia filosofem 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-05-2010 06:42 AM
Loop Library Opinions tha]-[acksaw General Discussion 7 09-14-2009 07:03 PM
From where can I download the loop library? tamasdragon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-15-2009 01:07 AM
Reggae Loop Library? lwilliam General Discussion 0 02-11-2007 04:58 PM
Any cool Loop Library recommendations? stephen duffy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-07-2004 04:21 PM
