Old 05-08-2017, 08:38 PM
legacygt777 legacygt777 is offline
Default pop/click sounds mixing problem help
when trying to mix, i notice a pop/click sound when my guitar solo is playing in a song. each individual track sounds good but together there's a small sound, like a static or pop sound. hard to describe.
ive tried compression and nothing helps except when i lower the volume but then i can't here the solo. am i peaking? help?
thanks
Old 05-08-2017, 09:15 PM
Default Re: pop/click sounds mixing problem help
Once you pin the noise down to one track(sometimes noises are actually a combination of more than 1 track, especially if timing is slightly off), you might be able to use the pencil tool, zoom way in and draw the click or pop out. If you zoom way in(so the wave shows as a line) and see a vertical line, that is likely the click. Maybe a search of youtube will turn up a video to assist
Old 05-09-2017, 10:14 AM
The Weed's Avatar
The Weed The Weed is offline
Sounds like clipping in one or more spots. Group and lower the entire mix?
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 05-09-2017, 03:33 PM
individually all tracks sound great.
Old 05-09-2017, 03:34 PM
i think this is the issue. i don't want to group....that's a lot of work lol
Click Track Problem - Default Sounds Missing Seitz333 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-11-2009 07:35 PM
are there better click sounds?? floriand D 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-19-2008 01:29 PM
ANOTHER 003 problem inputs 3-4 click sounds ostrange 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-09-2008 10:31 PM
Click sounds way bad Sidhu Pro Tools M-Powered (Win) 9 09-14-2007 02:24 PM
Different Click sounds? Rabidium 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-14-2004 01:28 AM
