MBox connected but PTLE says NOT connected
I have my MBox connected to my computer correctly and it was working fine just recently but it would light up, but not be functional. PTLE shows that it is Not connected, and I have all the right settings as written in the manual. I have uninstalled and reinstalled the software and tried all the troubleshooting for this problem, can you tell me what could be the problem?
Re: MBox connected but PTLE says NOT connected
Does PT give you this message at launch or during the session? My mbox would fail to be seen occasionally at the launch of PT In 6.1 and when I'd get this message, I could restab the beast and then it would recognize it. Also I have 2 firewire port on my Ibook and it wouldn't like the back port but it would work fine on the front port.
Hope this is of some help. |
I would also like to echo this problem. The LED's are on and when pushing play, the PT dialog comes up saying that the MBox is not connected to the USB which it obviously is. I reinstalled everything: System software, PT, Firmware and Core Audio. No results. No recognition.
Does the device show up in the Apple System Profiler under USB?
Does it have the correct name etc? Have you tried zapping the PRAM? (it may work - hold down option-apple-"P"-"R" when rebooting.)
He used to cut the grass...he was a very nice boy... |
Mbox Not Connected | AlphabetZebra | macOS | 1 | 11-03-2013 01:53 PM |
PTLE won't open w/out Mbox connected? | Welby | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-03-2006 10:48 PM |
PTLE will not work without hardware connected? | rcook349 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 09-28-2005 02:50 PM |
PTLE user needs help getting connected properly | The Wiz497 | ProControl, Control|24, Command|8 | 9 | 05-27-2004 09:38 PM |
MBox not recognized when connected | amishbob | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 04-18-2004 02:08 PM |
