Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire and USB Audio Interfaces (Win)
Old 03-11-2017, 05:36 PM
banjo71 banjo71 is offline
Default troubles at 48kHz in PT 12.6.1 with Focusrite Scarlett
I used to own PT 8 on Windows 7, using the Fast Track Pro. I used to have sessions in both 44.1 and 48kHz. I upgraded to PT 12.6.1 on Win 10 and got a Focusrite Scarlett 2i2 2nd generation audio interface. The Focusrite Scarlett software has a control panel for switching between 44.1, 48, ... up to 192kHz.
I can successfully open 44.1 and 96kHz sessions by switching to the appropriate frequency, but everytime I want to go to 48kHz, it won't play. I can open the session but it won't play. It will return an error,
"Pro Tools could not initialize the Focusrite USB ASIO. Please make sure that the device has been configured correctly."
I have to save and then after saving the session it freezes. I have to "x" out of the program.
The interface will work at all frequencies on other DAWs. And, I already made a ticket with Focusrite and they feel like it's not on their end.
Any ideas why it won't work?
Pro Tools 12.6.1 for Windows 10
ASUS Core i7 3770
Yamaha Steinberg UR 44
Golden Age Project Pre-73 JR
Glyph 1TB GPT50 external drive - Firewire
JBL LSR305 monitors
Neumann TLM102
Equation F.20 condenser mic
SM81 condenser mic
Old 03-11-2017, 06:58 PM
Default Re: troubles at 48kHz in PT 12.6.1 with Focusrite Scarlett
Are you allowing Windows to use the Scarlett as its default playback device?(Control Panel>Sound Properties). Changing that so Windows uses the on-board sound card might be the solution
Old 03-14-2017, 09:06 AM
JoelG's Avatar
JoelG JoelG is offline
I sometimes have to go into Control Panel, Sound and set the sample rate there too, especially if I connect my 18i20 to a different USB port - it detects it as another 18i20 not as previously connected (if that makes sense). I usually disable it in Control Panel, Sound after setting the sample rate. I also always use the same sample rate so I don't have to muck around with it often.
Joel
Jame Space:
HP Elite 6300 / Core i5 3570 / 12GB RAM / Win 10 Pro
Pro Tools 12 HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Intel S5000PSL / 2 x Xeon E5450 / 32GB RAM / Win 10 Pro
Pro Tools 12 HD / M-Audio Project Mix IO
Rig:
Eleven Rack / ART SLA1 / Fender Mustang V 412 / FCB1010 w/ EurekaPROM
Old 03-14-2017, 03:32 PM
Unfortunately I've tried all these things and it still won't allow me to transition to 48kHZ.
In ctrl panel> sound I've disabled all other sound cards, and also chose 48,000Hz Studio Quality in the playback and record tabs on the advanced tab. Inside a 48kHz session of PT, under set up, it says Focusrite ASIO device and when I launch control panel for it inside PT, it says 48kHz, 256 so I don't know why it has to be so hard.
I know everytime it plans on freezing up because when you open a session on 44.1, no clicks or pop upon opening the session. But when you hear a few clicks opening a 48kHz, you know it will freeze.
ASUS Core i7 3770
JBL LSR305 monitors
Neumann TLM102
SM81 condenser mic
Old 03-15-2017, 06:08 AM
JoelG's Avatar
Ahh, that's you're problem. In Control Panel, Sounds, you want to disable the Focusrite, but keep your built in audio as default for all Windows sounds.
Joel
Jame Space:
Home:
Rig:
Old 10-20-2019, 06:50 PM
NuBus NuBus is offline
Hi All
Hate to Drag up an old thread But I'm having this very problem
http://duc.avid.com/showthread.php?t=406829
My 18i8 is disabled in the Playback and Record Devices in the Sound Control Panel
Banjo71 Did you ever resolve this problem?
Old 10-28-2019, 08:01 PM
Originally Posted by NuBus View Post
Hi All
Disabling the Focusrite isn't the solution. Set the Windows Default Playback Device to the on-board sound card(realtek?). That leaves the Focusrite for Pro Tools to have exclusive use of
Focusrite Scarlett 2i2 2nd Generation and PT 12 banjo71 FireWire and USB Audio Interfaces (Win) 13 08-20-2016 08:27 PM
Focusrite scarlett 18i20 madselhoff Third Party Interfaces 6 01-25-2016 05:45 AM
Focusrite Scarlett 6i6 issues bootyt FireWire and USB Audio Interfaces (Mac) 2 12-12-2014 04:03 PM
Focusrite Scarlett - A Steal! RussUK General Discussion 45 05-12-2010 04:29 PM
Focusrite Scarlett justus1900 Virtual Instruments 1 12-18-2009 09:43 PM
