Old 12-31-2015, 06:39 AM
Terry Wetzel Terry Wetzel is offline
Default What happened to my plugins ? [SOLVED]
Hi guys. I've been working on a song now for about three weeks. everything has been operating exceptionally well compared to the usual pita interruptions I normally experience due to my inferior Creation Station pc. Now for no apparent reason my plugins have disappeared! None of them work! I haven't made any changes to my normal operating procedure! I may be jumping the gun by posting this before using my limited trouble shooting ability so please understand that I'm fed up with PT's and it's numerous, known only to the experts, reasons for these ridiculous interruptions! I've seen several posts lately about similar problems. I once had problems with plugin downloads not going to the proper file location but I thought that was behind me. Any help?
Old 12-31-2015, 09:12 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: What happened to my plugins ?
Has the location path changed in any way? renamed a folder etc. it should be system drive (Usually titled Mackintosh HD) > Library >Application Support > Digidesign > Plugins
Next thing to check is the ilok manager! install the latest version.
Ilok itself should be ok if PT is opening.
Are the plugins in the folder?
do they show in the plugins menu?
do they show in audiosuite menu?
Could just be corruption so trash prefs and re-install Pro Tools.
troubleshooting thread with details for trashing prefs etc... http://duc.avid.com/showthread.php?t=54888
All i can think of at the moment
chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 12-31-2015, 11:48 AM
The Weed's Avatar
The Weed The Weed is offline
Terry is on PC, Windows 7 32 bit IIRC.
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 12-31-2015, 12:10 PM
Nevermind!!!!
[IMG] code is Off
Where are my plugins [solved] Rob Hannon Pro Tools 12 9 04-05-2015 03:00 AM
PT 11 / Plugins do not render [solved] lies Pro Tools 11 1 04-03-2015 02:25 AM
How can I install new aax plugins in Pro Tools 11? [solved] Paul Sombric Pro Tools 11 5 09-05-2013 06:42 PM
New computer - What happened to the plugins? Earfatigue macOS 2 03-11-2012 10:50 AM
What happened to my plugins in Pro Tools? javianduncan Post - Surround - Video 3 06-07-2011 10:31 PM
