Old 02-17-2012, 10:30 AM
j.hall j.hall is offline
Default MacPro Optical output
ok, this is a weird one.
i monitor PT through AES 1/2 into a Mytek DAC. the DAC also has an spdif input.
so i've always used an optical to spdif converter so i can hear all computer audio through my same exact monitor chain, while PT is running and i'm working. i can quickly reference anything in itunes, quicktime, spotify, etc....
on my MacPro (8 core 3.2g harpertown) the optical out is not working at all. the mytek shows a constant -20db signal, but the line is silent. i've tried everything.
is this a CoreAudio issue?
i'm unable to delete the Avid CoreAudio plug-in. finder keeps telling me it's "in use".
on my old system, i removed coreaudio as it created some of these problems.
ideas?
btw, the optical to spdif converter box is fully tested and working.
Old 02-17-2012, 10:45 AM
cubivore cubivore is offline
Default Re: MacPro Optical output
if you're connecting optical out of the mac to the mytek you don't need to use the core driver for regular non-PT stuff like itunes, vlc, etc. just set the audio output to digital/optical in the system preferences. that's what i do with my macpro and lavry da10 so i can just toggle on the da10 between rca (PT) and optical (mac).
Old 02-17-2012, 11:05 AM
i just booted my old machine, and everything works fine. (PPC G5 running tiger)
so either i have a bad optical output on the MacPro (8core 3.2g Lion), or i'm simply missing something.
Old 02-17-2012, 11:20 AM
i got it working.
chalk it up to a strange apple thing.
in prefs "sound" pane, i select internal speaker, quit prefs, launched itunes, hit play. quit itunes, reopened prefs, sound pane, selected optical output, quit, launched itunes, hit play, it worked.
WEIRD.
thanks for the help!
[solved] No sound thru MacPro Built-in Line Output with PT10 Lakhbir macOS 9 11-13-2011 08:08 PM
3 monitor output mix/edit/quicktime Macpro bigsmokeaudio Post - Surround - Video 12 02-24-2011 08:48 AM
G5 Optical Output to 192 Optical Input Irl Sanders Pro Tools TDM Systems (Mac) 1 08-22-2005 06:38 PM
HELP!!!!!! OPTICAL OUTPUT Mr_Seven 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-13-2002 03:49 PM
Optical Output? Gato75 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-23-2002 11:20 PM
