Old 02-05-2011, 08:34 AM
dodlum dodlum is offline
Default Eucon Crashing PT
Hi Just looking for any help or ideas...
I have an MC mix - when I open a session with Eucon enabled PT crashes. Pro Tools opens and I can select eucon in the peripherals fine - just at the end of the progress bar of a session opening it quits.
I have the latest version of PT and Eucon (though I did download the latest version of Eucontrol and the installer is call 2.5.6 but the app version after I install it is 2.5.4).
I have un- and re-installed both Eucon and PT.
Thrashed prefs in home and HD libraries (of both Eucon and PT)..
It works fine in HUI mode. I have tried with PT deleted from the Eucon system pref...
I'm on 10.6.4, Eucon 2.5.6, PT 9.0.1, HD 2 using a magma PE6R4 - Macpro 8x3ghz - 8 gigs ram.
Could anyone post for me an idiots guide to setting it up - I have done it as per the manual and to no avail.. Just wondering if I'm missing something.
Thanks in advance for any thoughts or help,
David
Old 02-05-2011, 10:54 AM
GW GW is offline
Default Re: Eucon Crashing PT
User configurations. Where to look -
Macintosh HD/Library/Application Support/Euphonix/UserSets/MC2User/MC_USER_SET__Root/
Here you should have a file called Pro Tools 9Mac.xml for your setup to work in EuCon mode in 2.5.6 with PT 9 and don't forget to check the box for EuCon mode in the settings menu in PT
It's easier to see on the Transport or Control if it's loading correctly since it clearly states "Pro Tools 9Mac"
You can alos look here -
You find your prefs here (if you need to trash them or back them up) -
House(+name)/Library/Preferences/ called: com.euphonix.eucon.plist and com.Euphonix.EuControl.plist
House(+name)/Library/Preferences/Euphonix/ called: EuControl.cfg
Macintosh HD/Library/PreferencePanes/ called: Euphonix.prefPane
PT 12.4.0, iMac 27" Retina 4GHz i7, 32GB RAM, PoCo x8,
Digi002 Fact., Logic X|FCPX|Motion
Plugins: Waves Diam. V9|Artist Sign Ser.|SSL|GTR3.5, TC MD3|Harm4|VSS3|DVR2|Nonlin|Unwrap, Sonnox Infl|Dyn, Autotune
VI: Reason 8, Ivory It., Trilian|Omnisphere, VG2/RealGuitar, Kontakt6|GPO, Goliath|Gypsy|Fab Four, Candy, Structure, EZdrum, BIAB Audiophile
Hardware: TLM49|TLM103, SPL Track One, TC M-One, Artist Contr.v2|Transp|3xMix
Eucon Windows BUG: some windows r stuck in background when Eucon running. TuckerMix Artist Series 12 07-08-2014 02:37 PM
EUCON 2_6_1 eucon discovery cant find ip klaukholm System 5 2 10-22-2011 01:01 PM
Alert - EuCon 2.5.6 is only for Pro Tools 9 and EuCon DigiTechSupt Artist Series 11 02-24-2011 11:25 PM
EuCon 2.5.6 with non-PT DAW? surroundsfx Artist Series 3 11-29-2010 01:52 PM
Eucon and PT HD 9 soundworx Pro Tools TDM Systems (Mac) 2 10-26-2010 11:42 AM
