Old 11-19-2010, 02:20 PM
DesertMoney DesertMoney is offline
Default Help!! scribble strip display, dark
My first 8 scribble strip display is dark and the buttons doesnt function
Old 11-26-2010, 06:37 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Help!! scribble strip display, dark
Usual cause of these type of problems is the cable connection to the bank of 8 scribble strips! and also the connections to the power supply on the back? Quite often a really good clean and reseating of all the connections to the power supply will fix these issues.
They sometimes come and go with temperature changes as the connections heat and expand etc, this is usually the first sign of a poor connection somewhere.
If its not a cable/connection issue then it could be something more serious on the controller board for that bank.
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Control 24 Dark scribble displays Firechild Pro Tools TDM Systems (Mac) 4 11-03-2011 09:45 AM
Scribble Strip Display tim carter ICON & C|24 2 01-24-2010 06:25 PM
scribble strip going dim off and on WilliamDC ICON & C|24 2 08-29-2006 09:31 AM
Anyone else losing scribble strip display? johnnyv ICON & C|24 5 12-09-2005 05:36 PM
scribble strip syntheticrhyme ICON & C|24 1 05-15-2002 08:22 AM
