Old 05-05-2008, 09:27 PM
ggonda ggonda is offline
Default scribble strip displays HR instead of track name
Hey All,
Like the title says, on every scribble strip on my ICON displays HR plus a number (ex: HR-3.5) on every channel. I can't figure out why it doesn't display the track name listed in PT and I noticed everytime i hit clear clip, the number changes. The number never passes 0.0, also. Can anyone tell me what this means since I'm such a newb? Thanks in advance.
Old 05-06-2008, 01:34 AM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
Default Re: scribble strip displays HR instead of track name
hmmmmmm ......
You on D control or D command ?
Anyhow ... look for a button that says 'disp mode' on your global channel strip ... just under the 'mute clear' button on D control and on D command in the neighborhood of the 'do to sel' button ...
See if that changes anything .... it should really ....
Now .... fwiw ... 'disp mode' basically is an abbreviation for 'display mode'
HR would be the abbreviation of 'headroom'.
Headroom being one of THE most important things to understand and know about when working with digital audio it is included in the display modes. It allows you to monitor your headroom ... it tells you how much of it you have left. Which at the same time is also why it doesn't go higher then Zero dBFS (full scale digital) ... there is no higher then zero dBFS .
Hope this helps.
Chris Lambrechts
Applications Specialist- Live Sound
Control 24 scribble displays flickering? please help primomusic ICON & C|24 7 01-29-2013 08:43 PM
Control 24 scribble displays flickering? please help primomusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-22-2013 02:27 PM
Control 24 Dark scribble displays Firechild Pro Tools TDM Systems (Mac) 4 11-03-2011 09:45 AM
Control 24 "Scribble Strips" - two displays not working Kevin Mowry ICON & C|24 6 07-26-2008 12:19 AM
scribble strip syntheticrhyme ICON & C|24 1 05-15-2002 08:22 AM
