Old 03-16-2007, 02:07 AM
Andrew Wright Andrew Wright is offline
Default Pro Tools LE 7 Dead After OS X Automatic Software Update
Hello,
Did a major auto software update the other evening inc Quick Time and iTunes, now when I go to open Pro Tools LE7 on my Intel mac it just bounces in the dock !
Has anyone else had this problem, and is there a fix ?
Is it an iTunes issue ?
Any help appreciated.
Thank you
Andrew.
Old 03-16-2007, 02:22 AM
citrusburst citrusburst is offline
Default Re: Pro Tools LE 7 Dead After OS X Automatic Software Update
Hi Andrew,
I had the same problem. It's actually the upgrade to OS 10.4.9 that's the problem. For what it's worth, ProTools users aren't the only ones bothered - there have been problems reported all over the web related to this update.
Anyway, go here:
http://duc.digidesign.com/showflat.p...64#Post1128964
and download the "Combo Update (Intel)". Install it, and ProTools should begin running again. (It worked on my machine.)
Note that even after the Combo Update, PT is a bit buggy. At least it runs. For smooth sailing, we'll likely have to wait on further updates from both Apple and Digidesign. Just guessing.
Hope that helps.
Jed
Old 03-16-2007, 03:24 AM
Thank you so much for the info
Old 03-16-2007, 11:15 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Always check with the Digi compatibility docs before upgrading to anything.
"Compatibility Alert — Mac OS X 10.4.9
Mac OS X 10.4.9 has not been qualified with Digidesign products"
I would also suggest turning off the automatic download.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
9.0.6 automatic update failed / laptop, Lion. crizdee macOS 1 02-01-2012 03:15 PM
Pro Tools 8.0.1 Software Update Available Avid Pro Tools TDM Systems (Win) 0 09-08-2009 01:58 PM
Pro Tools 8.0.1 Software Update Available Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-31-2009 04:34 PM
Pro Tools 8.0.1 Software Update Available Avid Pro Tools TDM Systems (Mac) 0 08-31-2009 04:32 PM
does pro tools automatic update include plugins nossnevs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-27-2009 10:42 AM
