Old 01-24-2006, 07:02 PM
Ken P Ken P is offline
Default XP SP2-turn off \"hot keys\"?
wondering if this is a common PC thing - when i go to export a file or something and when i name it, if i hit certain keys it's like they are shortcuts or hot keys for "tab to program", "lock computer", etc. right in the middle of a session i must have turned this on or something, i had to limit what i called files in fear of triggering something else to happen without letting the client think i was an ameture
anyone know what i did and how to turn it off??
Ken P.
Pro Tools HD on PC
Pro Tools LE on Mac G5 and MacBook Pro
Old 01-24-2006, 09:33 PM
Default Re: XP SP2-turn off \"hot keys\"?
Couple of possibilities.... You have a stuck modifier key.. try toggling them... or you enabled StickyKeys accidently.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 01-25-2006, 07:46 AM
bigdude bigdude is offline
this happens to me frequently but i'm stil not quite sure how it happens
becareful - a few times i've locked the OS out and my password has characters that don't work and are acting as shortcuts.... :-(
what i have found to get back to normal is holding the control key and then pressing all the "F" keys (still not sure which one undoes it)
hope it helps
thanks
Old 01-25-2006, 11:02 AM
jeff markham's Avatar
jeff markham jeff markham is offline
This really sounds like StickyKeys got turned on .. basically,
if you hit a modifier twice closely together (in time), it will
stick it (like capslock .. but it works on control, shift and Alt.).
jeff
PS: here's how you turn it off:
1. Press SHIFT 5 times consecutively. The StickyKeys box will pop up.
2. Click Settings. Accessibility Options pops up.
3. On the "Keyboard" tab click the "Settings" button in the "StickyKeys" section.
4. Uncheck the items in this window and click OK.
5. Click Apply and OK on Accessibility Options.
Joe Barresi & Tony Shepperd Master Series
http://techbreakfast.com
Pressed some keys now shortcut keys wont work (T,R to zoom etc) Falcon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 06-11-2016 11:49 AM
Can't turn off Mac Function keys/turn on PTLE Shortcut keys b mcgibney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 09-25-2009 10:15 PM
to turn off 002 or not to turn off 002? that is the question andy1908 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-07-2007 11:47 AM
Quick-keys..& X-keys Ru_C Pro Tools TDM Systems (Mac) 10 10-24-2006 12:13 PM
function keys don't work as quick keys miked45 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-21-2003 11:32 AM
