Old 09-13-2019, 10:50 AM
pablormago pablormago is offline
Default Internet Sharing on Mac with PT Control problem
Hi to all, so the thing is:
We are making a wifi hotspot with the Internet Sharing option in Mojave.
If we put the Wifi adaptor ip to DHCP the PTControl dont works.
If we put it on Manual, and set the Wifi Ip to 192.168.2.1 and the subnet to 255.255.255.0 it WORKS.
The problem is that when we reboot the Mac it does not works, we have to put it on Dhcp and then to manual again to let the PTControl works.
Any idea???
Thanks in advance
Old 09-13-2019, 12:13 PM
BScout BScout is offline
Default Re: Internet Sharing on Mac with PT Control problem
Assign the iPad a static IP address of the 192.168.2.xxx format. You do this on the iPad in general settings when it is already working with the computer. Only have to do this once.
What's happening is your iPad is on DHCP so it needs an address. If you reboot your Mac, it loses its address. When you put it on DHCP it regains an address. Then when you put the Mac in manual, the iPad has an address to use on the same address octet as the Mac.
Giving the iPad a static iP means it doesn't need the Mac's DHCP to get one.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 09-13-2019, 12:31 PM
Still not working.
Everytime I reboot the Mac, i need to chance the wifi IP to other in the same range and apply... Example: From 193.168.2.1 to 192.168.2.4
I attach the wifi config on mac and ipad.
Thanks in advance
Enviado desde mi SM-G950F mediante Tapatalk
Old 09-13-2019, 01:36 PM
Originally Posted by pablormago View Post
Still not working.
Everytime I reboot the Mac, i need to change the wifi IP to other in the same range and apply... Example: From 193.168.2.1 to 192.168.2.4
Which Wifi IP? On the Mac or on the iPad? The iPad's wifi connection parameters should be attached to the SSID of the wifi it connects to. So if the Mac doesn't change its SSID name for its hotspot, the manual setting should stick when the iPad connects.
Is it changing itself to automatic DHCP on the iPad?
Old 09-16-2019, 12:49 PM
I mean i have to change the wifi adapter ip on the mac, and then it works again...
Mac and ipad are on Manual for their IP
App does not work with internet sharing LukeHoward Avid S1, S3, Dock and Control 1 09-18-2015 04:11 AM
Internet Sharing Large Files/Folders? wdjudd Pro Tools 10 6 01-28-2013 06:37 PM
sharing sessions across the internet.... evon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-28-2010 12:32 PM
Control 24 sharing between 2 computers Table Syrup Records ICON & C|24 7 11-11-2008 04:18 AM
Can I use the internet and the control 24 at the Brandonx1 Pro Tools TDM Systems (Mac) 2 03-15-2005 07:31 AM
