MC Control accessing RTAS\TDM plugins
I know you can edit any parameter within each Plug ins within Pro Tools 9 with the MC Control but is there a button that brings up your RTAS Insert plug ins (on a selected track)? I know the D-Command has a button that brings up the RTAS\TDM plug ins so I'm sure the MC Control has to have one. Does anyone know what it is or if there's a keyboard shortcut for accessing insert plug-ins?
Re: MC Control accessing RTAS\TDM plugins
I´m not quite sure if I understand you correct but any inserted plugin you can bring up like this:
Press the BACK key until the top-level knobset is displayed on the Touchscreen. Press the INSERTS Soft Knob the names of the plug-ins on that track are distributed across the Soft Knobs. Press the Soft Knob beside the desired plug-in’s name to select it. |
Thats awesome. Basically, im trying to setup macros within Eucontrol and Quickeys for my fav insert plugins.
For example, i always have sessions where i need to create a new track with a certain compressor and autotune. I wanna setup 1 button to do that but i got stuck when i was trying to access the insert plugin menu because there's no keyboard shortcut for it. The D-command has a button that brings up the dropdown menu for your available plugins and i was praying the mc control had a feature like that So do you think thatll work? I cant wait to get home and try it out |
If you find out how to do that, please let us know.
PT 12.4.0, iMac 27" Retina 4GHz i7, 32GB RAM, PoCo x8, Digi002 Fact., Logic X|FCPX|Motion Plugins: Waves Diam. V9|Artist Sign Ser.|SSL|GTR3.5, TC MD3|Harm4|VSS3|DVR2|Nonlin|Unwrap, Sonnox Infl|Dyn, Autotune VI: Reason 8, Ivory It., Trilian|Omnisphere, VG2/RealGuitar, Kontakt6|GPO, Goliath|Gypsy|Fab Four, Candy, Structure, EZdrum, BIAB Audiophile Hardware: TLM49|TLM103, SPL Track One, TC M-One, Artist Contr.v2|Transp|3xMix |
If you alway use the same compressor and autotune why not make a session template with those plug ins. Then you have it all set up and can bring the plug ins up via the MC control.
The scenario I'm referring to is when I record a singer and I'm constantly adding additional tracks as needed. It would be so awesome to press 1 button when I need another track as opposed to several button, scrolls and clicks for each track.
Mac Mini 2.5 GHz Dual-Core Intel Core i5 - 16gb Mem - MacOS Catalina 10.15.5 - Pro Tools 2020.3.0 |
What I often do in this case is duplicate the track without the Active Playlist, Alternative Playlist or Automation options selected. Then you get a new blank track with all the right settings to use immediately.
PT crash when accessing Slate Trigger 2 from Artist Control/Mix | ThomasHQ | Artist Series | 2 | 01-20-2014 12:54 PM |
Accessing Score Editor On D-Control - Bug? | GlennR01 | ICON & C|24 | 3 | 06-06-2009 06:04 PM |
accessing Trillium Lane plugins | Filmpool | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-15-2007 10:13 AM |
Mbox Pro2 FACTORY Plugins - Accessing | modemdavid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-23-2007 08:11 AM |
Pro Tools 5.2 on launch freezes when accessing Machine Control Window | [email protected] | Pro Tools TDM Systems (Mac) | 0 | 04-12-2003 07:42 PM |
