Space convolution impulses
I am interested in buying Avid's space because it is AAX (I am not getting Altiverb because it is not DSP otherwise I could get Altiverb). For Space I am looking for a large number of impulses specifically for: forest, country, street, lake, etc. really 'realistic outdoor impulses'. I am using this exclusively for post not for music. Are these outdoor impulses available either form Space or another library that I could use in the space plugin?
Re: Space convolution impulses
I haven't tested this myself but heard very good things about it:
http://www.boomlibrary.com/boomlibra...ulse-responses
my blog:Tamas Dragon |
Thank you, I will look into the boom library
+1 for the Boom Library Impulses.
There are other good free ones out there on the web, just do a search. Or you can make your own from gunshots or fireworks etc. Personally I tried Space for post for the same reason that it is DSP. I liked it, its flexible and it sounds good, but is sadly lacking in ease of automation. I would try the demo and make sure it can do what you need first. I also found it has quite a hit on the host cpu, even though it runs on HDX.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12 |
They seem to tout their snapshot automation for Space. What is it that's lacking exactly?
"In addition to presets that save both the IR waveform and control settings, Space also enables you to manage a group of settings called snapshots, which you can quickly switch between using a single, automatable control—very useful in audio post production for firing different reverbs at scene changes." |
Interesting that it would hit the CPU hard being DSP, if that is how it works it may not be worth getting. Great heads up, thanks! I will TRY before I buy. |
In a big feature you could easily run out of slots and then you're done, apart from using another Space. Altiverb used to be the same until they allowed all the reverb parameters to be individually automated, getting around the limitation and allowing unlimited scene changes. As for the cpu hit, I have no idea why. A bit of a shame with all those processors idling away on the HDX card.
avoid - and get exponential audio's reverbs
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
EA sounds good but it's a very different reverb. I have both but EA is not going to replace AV for many things, IMO.
Since PT11 AV's memory hunger is not an issue anymore. And since they got rid of those preset slots and automate all parameters the automation hickups have gone away entirely for me. However, I've seen many people still use the presets slots AND the parameter automation at the same time. This is where the problems start. You should only use one OR the other. Here's a good explanation from Aram regarding this: Quote:
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron Last edited by Frank Kruse; 02-02-2015 at 09:24 AM. |
Rolling your own impulses for TL Space | TheLoneRoger | Pro Tools 9 | 1 | 05-25-2011 09:25 AM |
TL Space / cab impulses? | ktwalker76 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-09-2011 09:12 AM |
TL Space Impulses Missing | guitar486 | Pro Tools 9 | 26 | 12-01-2010 10:05 AM |
Imported Logic 7.2 Impulses to TL Space! | guitar012001 | Pro Tools TDM Systems (Mac) | 1 | 03-09-2006 12:52 PM |
Impulses for convolution reverbs | =GF= | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-23-2004 02:45 AM |
