Old 09-12-2018, 01:38 PM
Scott G Scott G is offline
Default 50fps session?
I have been asked to mix a documentary and apparently it will be edited and was shot using a 50fps frame rate. How do I deal with this in ProTools? I haven’t found that frame rate as an option. I have only worked at 25fps. They will be supplying an AAF.
Thanks
Scott
Auckland New Zealand
PT2022.5 Focusright RedNET 8Pre, RedNET R1
Z690 AERO D Workstation, I7 3.6GHz 12 core, 64GB RAM, Win10 Business 64bit
Old 09-12-2018, 03:48 PM
mfranken's Avatar
mfranken mfranken is offline
Sounds In Sync
Default Re: 50fps session?
Hi Scott,
You can't set the main counter or ruler to 50FPS but you can set the second ruler to 50FPS. You can then set your grids to 1/2 frames if you want a grid on every 50FPS frame.
On a side note, if you will need to re-conform for picture changes during your sound post, EdiLoad can re-cut your session at 50FPS.
Regards,
Mark
Mark Franken, MPSE
Dialogue editor/supervisor IMDb
Creator of 'EDI' applications for sound post editors
www.soundsinsync.com
Old 09-12-2018, 06:09 PM
Thanks Mark.
I don't think I'll be needing a grid I just wanted to be sure that the session and the video file they supply play at the correct speed.
Scott
Scott
Old 09-12-2018, 08:35 PM
mfranken's Avatar
Sounds In Sync
Yes. Just set the main frame rate to 25FPS and PT will play the video at 100% speed and you just edit and mix as usual. The movie info on the video track should display 50FPS.
Regards,
Mark
Mark Franken, MPSE
Old 09-13-2018, 01:36 PM
Chears Mark.
Scott
Scott
HTML code is On
Save session, close session, open session next day...clips have moved. ptr22 Pro Tools 12 8 02-18-2016 06:34 AM
Pro Tools 9 crashes every time I open a new session or import session data Ryan Butler macOS 14 03-23-2014 07:53 AM
Audio Files Moved or Removed from Session after Saving Session Copy for Protools 9 doubtful guest Pro Tools TDM Systems (Mac) 1 02-06-2013 03:42 AM
Vacuum patch gets shorter decay time at 96kHz session than 192kHz session chrisdee Virtual Instruments 21 10-07-2011 10:02 AM
End of Stream Reached - session broken - import session data does not work... Sean Russell Pro Tools TDM Systems (Mac) 0 01-15-2010 04:56 PM
