Old 09-24-2002, 08:23 AM
vlad vlad is offline
Default New noise in my Digi after adding video card, please help!
Ok, at first I was very excited to actually upgrade part of my system yesterday by installing an ATI Radeon 8500 Mac edition card.
THEN, I got my G4/400 back to the studio, and fired it up only to be completely bummed out by noise that comes through the Digi. This noise sounds like a constant high pitched squeal, combined with pink noise that changes pitch depending on the tower's activity.
This happens with the Monitor button on the Digi IN or OUT. The volume control has little effect on this noise.
The noise actually starts as soon as I power the machine on, as the screen is blank even. I'm pretty sure it's got to be hardware related. The presence of the Digi extension made no difference.
As the display changes resolutions, loads new images or the hard drive reads or writes is when I can hear a change in the sound. I have to listen back through this noise if I play a mix back.
Anybody have a similar experience? Is this just an incompatibility between the digi and the radeon? I've tried moving the digi away from the AGP slot, and even putting my ATA100 card between them.
I ran Digitest and everything checked out fine, reseated cables, disconnected anything I didn't need...
Any suggestions? Would this even warrant a return on ATI's part?
[img]images/icons/mad.gif[/img] Martin
Old 09-24-2002, 03:11 PM
Default Re: New noise in my Digi after adding video card, please help!
Other than taking it back, any thoughts, similar experiences? Anyone? Digi?
Old 09-24-2002, 06:50 PM
Deirdre B's Avatar
Deirdre B Deirdre B is offline
Dear Vlad:
Thanks to you, I have found the source of MY annoying whine. I thought it might have been in my USB audio interface, but after pulling the extra video card, (ATI Radeon 7000) my audio channel is clear!
I don't know how I'm gonna work around this, since I prefer to have two monitors when working with graphics...but since this problem has been with me since I GOT my G4 (with the extra card installed by my Mac Guys!!) I'm just glad to know what the hell it is.
Your Pal
Deirdre B.
Spiffy i7 Mac Mini
2 SSDs
Yosemite 10.10.5
PT 11
Never Stop Playing.
DBCooperVO.com
Old 09-24-2002, 10:59 PM
Cornbread Cornbread is offline
Hey, I have the same problem as well. High pitch noise coming from the output of the Digi001 and I also recently installed an AGP Radeon 8500 into my 400mhz G4. Annoying as hell!!! I was wondering why it was doin that. [img]images/icons/frown.gif[/img]
Old 09-25-2002, 04:25 AM
Deirdre B's Avatar
This isn't just a G4 400 issue--!
My Mac is a Brand-new Dual 1 gHz Quicksilver G4. What a hoot that I may need to bring back the old Beige G3 to record sound if I want to keep my second monitor!
man.
DB
Spiffy i7 Mac Mini
2 SSDs
Yosemite 10.10.5
PT 11
Never Stop Playing.
DBCooperVO.com
Old 09-25-2002, 06:12 AM
kite kite is offline
for what it's worth, I have Mac G4 450, with AGP graphics, and I use a Pro Max AGP graphics card, and run 2 screens - trouble free installation, and no extraneous noises ! It runs a CRT 19" and a LCD 15" -cost about £300 and is Digi/Pro Tools friendly . However have just tried to find info on their site - http://www.promax.com but can find no reference to such card. Does this mean they no longer manufacture or support it? No sooner does a good Mac product come along than someone decides to discontinue it -hope not.
www.kitestudio.co.uk
Mac Pro
Snow Leopard
003 & Midas Venice desk
Mindprint DTC
Soundelux U99
Drawmer M-Clock
Old 09-25-2002, 08:16 AM
Nine Spine Nine Spine is offline
Mac G4 733 QS, 1.5 gig RAM, (3) Internal ATA Drives, and an ATI Radeon 32megDDR PCI Video Card (The only other PCI Card installed other than Digi...and AGP Slot) and I have absolutely no audio problems whatsoever. I do get the "PCI Bus too busy" errors from time to time if I am not careful though. For the record I am running (2) Sony 20" Trinitron Monitors.
I don't have a solution...just pointing out that I am not having this problem. My Digi PCI and my ATI PCI are seperated by an empty slot...don't know if that has anyting to do with it, I think I remember you saying you tried that already...
I.B.S. Studios
Old 09-25-2002, 09:42 AM
Deirdre B's Avatar
The queer thing for me is that the PCI Radeon card was causing noise thru the USB audio interface.
THAT is wacko.
Spiffy i7 Mac Mini
2 SSDs
Yosemite 10.10.5
PT 11
Never Stop Playing.
DBCooperVO.com
Old 09-25-2002, 10:18 AM
I'm SOOOO glad I checked this again before requesting another card be shipped from the supplier.
Deirdre, I'm glad you replied and that I'm not alone. Have you removed that 7000 to make sure the noise goes away?
Cornbread, have YOU removed it and gotten the noise to stop?
Last night i made the time to put my Rage 128 card back in, and the noise went away. This was of course, after I tried my last effort of troubleshooting:
I downlaoded the 1.26 firmware updater, and tried running that and got an error type 2. restarted, tried again, same thing.
I tried flashing it back to 1.23 and it worked and I rebooted.
Tried flashing it back up to 1.26 and it quit with a Type 1 this time. Figured maybe an extension conflict was happenning so I booted holding shift, only to boot to a blank screen.
Zapped PRAM with keys, nothing. Powered off and used the CUDA button, and still nothing.
OS X.2 has the drivers for this card natively, so I booted and held Ctrl-X to switch the startup disk to OSX. I could hear it happen, but it came up blank as well. I think this card died.
Put in the RAge, and low and behold, I don't have to listen to mixes through static and noise, and I can get display now!
Now I guess I have to decide to go with another card, abandon the idea altogether, or attempt getting a replacement for this card.
Martin
Old 09-25-2002, 10:35 AM
Deirdre B's Avatar
Dear Martin:
Yes--I have removed the card and the noise disappeared. Another funny thing is this Radeon card DOESN'T have a little fan on it. Like, whatever.
I'm writing a report to ATI right now and sending them a link to this question on the DUC.
Your Geekette
Deirdre B.
Spiffy i7 Mac Mini
2 SSDs
Yosemite 10.10.5
PT 11
Never Stop Playing.
DBCooperVO.com
Adding 3rd card++removing video card for G5 gsilbers Pro Tools TDM Systems (Mac) 3 03-14-2010 04:44 PM
Digi 001 & AGP Video Card Problem Popcorn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 08-22-2009 05:44 AM
Digi sharing IRQ With video Card Olly J 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-06-2002 05:54 PM
Digi 001 with Matrox RT MAC video capturin card on Apple G4 Renato 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-20-2001 11:17 AM
Digi Sound Drivers with FUSE Video Card Irl Sanders Pro Tools TDM Systems (Mac) 3 06-09-2000 08:24 AM
