Old 12-28-2014, 07:22 PM
jackson92119 jackson92119 is offline
Default Adding multiple video clips in Pro tools
Hello. I am trying to add multiple video clips in Pro tools, I can add one clip, but when I go to add another one Pro tools ask me "Do you want to replace the movie currently used in this session?" then If I do that it replaces my original clip with the new one. How can I add multiple clips? Thank you. Win 7, Pro tools 8
Old 12-28-2014, 09:26 PM
Buccanears's Avatar
Buccanears Buccanears is offline
Default Re: Adding multiple video clips in Pro tools
Hi Jackson, multiple video clips are only available with DV Toolkit 2, Complete Production Toolkit or a full HD license. With vanilla, it's just the one.
Alas, DVTK and CPTK are no longer available from Avid, but you might find a 2nd hand one.
Q "where are your buccanears?"
A "on your buccanhead!"
IMDB
Old 01-03-2015, 06:48 PM
Park Seward's Avatar
Park Seward Park Seward is offline
If you really need to see more than one movie, you could do a quad split in a program like Final Cut Pro. You could then run that movie in PT and it would only count as one stream.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 01-03-2015, 09:58 PM
Thanks, I kinda did this using After effects. I took all the clips put them togther and imported them into Pro tools
Multiple Video Clips 19 frets Pro Tools 11 5 05-08-2014 10:08 AM
Writing Automation to Multiple Clips in Pro Tools ericlawrence macOS 1 01-10-2014 01:47 PM
Video frame/field offset when using multiple clips in PT soundboy35 Post - Surround - Video 1 11-16-2008 05:33 AM
PT 7.2 and Multiple Video Clips Question laki Pro Tools TDM Systems (Mac) 1 08-14-2006 01:23 AM
Importing Multiple Video "Movie" clips into PT6 David Hunter Pro Tools TDM Systems (Mac) 9 07-04-2004 11:53 AM
