Old 06-26-2011, 06:59 PM
End Over End End Over End is offline
Default File transfer settings Mac transfer to Windows ?
Question:
What exact detailed critical settings need to be observed when moving sessions from mac to windows and vice versa?
I am very new to pro tools (9) yet a master of Sonar on PC only.
A client brought me a pro tools session but on my Win machine the .ptf file extension is not showing up - this was saved on a Mac obviously.
Or mainly why would the file exstension be "greyed out" (not there) on windows when coming over from a Mac?
concise tech talk is in order...
Thanks.
EOE
Old 06-26-2011, 08:45 PM
Alexmc1988 Alexmc1988 is offline
Default Re: File transfer settings Mac transfer to Windows ?
Interesting, I haven't ever had any problems going between Mac and Windows. Just copy the session folder and go. Wish I knew how to help.
Old 06-27-2011, 03:54 AM
jntracks jntracks is offline
well mac doesn't need file extensions to be in the name to determine what kind of file it is. so it's possible that this mac was saving the file with out an extension. you can add it but renaming the file.
the only thing that needs to happen when saving the session file make sure "ensure mac/pc compatibility" is checked.
-j
www.jntracks.com
Old 06-27-2011, 04:09 AM
stevedemena stevedemena is offline
Default
I think current Macs DO need file extensions to determine what application to use to open a file. (Snow Leopard)
Steve de Mena
Mac Pro Late 2013, 32GB 6 Core, 10.10.4, PT HD Native 12.1, Apollo Quad TB
MacBook Pro 15" Retina i7 - 16GB, PT HD (mixing only)
Old 06-27-2011, 12:59 PM
Thanks for the tips.
PT9.0.3 on Win error says the file was made in a newer version of PT
this is a PT7.4 file from a Mac.
Renaming the file by adding extension is afail or am I missing something?
And why wouldn't Avid make the files Win/Mac compatible by default ? FAIL
Thanks.
Old 06-27-2011, 01:18 PM
DarylG DarylG is offline
Thanks.
That is a very good question. I guess it's just a hang-over from the old days that never got changed. However, if the file is from PT 7.* it is already a bit of a dinosaur. Besides lesson one in using PT engineers are taught to check the PC/Mac compatibility box. Anyone who doesn't' do that is just incompetent, IMO.
D
ProTools 9.02
2 x Intel Xeon x5675 3.07GHz Hex Core
48GB RAM
Windows 7 (x64)Pro
RME Multiface II
Intensity
ATI HD5400 series graphics card
Old 06-27-2011, 03:17 PM
Thanks.
As said, since PT7, session folders can move between Mac and PC without issue(God forbid you are still recording in SD II format though). I have had zero problems moving session folders between my LE/PC rig and a friend's Mac/HD setup
Old 06-27-2011, 04:53 PM
Thanks, All
On which platform is the checkbox for Mac / PC compatibility?
and under which menu.
This subject may allow me to specify my needs when moving files back and forth.
when the sesh doesnt open and everyone is there .....
OK
Old 06-27-2011, 06:32 PM
JMS40 JMS40 is offline
Thanks, All
As albee pointed out, that option is only found on versions prior to PT 7.
EQ-II / EQ-III Settings Transfer? bradjacob Pro Tools TDM Systems (Mac) 9 10-24-2008 09:18 AM
MIDI File Transfer - Logic (Mac) to PT (Windows)? EarBud 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-01-2008 06:00 PM
Transfer Plug settings fron Mac to Windows? EGS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-19-2005 06:24 PM
File transfer bet. mac &windows mr.schmitz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-22-2004 11:02 AM
going from 001 windows to hd3 mac - file transfer digi2000 Pro Tools TDM Systems (Mac) 4 04-24-2002 12:33 AM
