Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 04-05-2006, 10:36 PM
paulconstantine paulconstantine is offline
Default Mac OSX 10.4.6
Has anyone updated their Mac OS yet? Did everything work alright?
Old 04-06-2006, 10:44 AM
sculptor 1 sculptor 1 is offline
Default Re: Mac OSX 10.4.6
Hi there
works fine for me with protools 7.1 and logic 7.2
Old 04-06-2006, 09:48 PM
Loudnoize Ent. Loudnoize Ent. is offline
PT 7.1 with MPT works perfect here as well except I believe there may be compatibility issues with some Waves and Altiverb plug-ins. Check their websites.
Old 04-15-2006, 04:15 AM
jbmelby jbmelby is offline
I have an M-Audio Delta 1010LT sound card on my MDD 1.25 GHz Dual running Mac OS 10.4.6 with 1.5 GB RAM. I've been trying to route output to analog outputs 1-8 of my card, but it appears that I can access only outputs 1 and 2. I tried using M-Audio's v 2.0.5 driver for the Delta cards, supposedly the most current version, which doesn't seem to work. I downgraded to v 2.0.3 of the driver, which worked for a short time, but after a while outputs 3-8 disappeared again. After numerous consultations with M-Audio Tech Support, I've concluded that either the card or PTM-P just doesn't cooperate with 10.4.6. Luckily, I have another partition with 10.4.3 on it, and everything seems to work there.
There is an annoying problem with the 1010LT, though: with it installed, the CPU will not sleep under any circumstances. This is apparently a long-standing problem with this card.
Mac Pro 8-core 2.4 GHz, 10 GB RAM, Mac OS 10.7.1, PTMP 8.0.5, M-Audio Firewire 410 (driver version 1.10.3)
