Old 10-18-2005, 07:35 PM
will the moor will the moor is offline
Default edit the entire file after it\'s been chopped
Hi duc
I have a vocal track that I've chopped a bunch of stuff out of (noise and the like) so the track has like 10 regions on it now. I'd like to run the gain command on the entire track, destructively editing the original file but I'd like to keep all my chopped regions. Is there a way other than opening it in another editor, adjusting the gain and saving the file? Doing that is no big deal, I'm just wondering if there's a way to do it directly in PT.
I'm afraid I'm not asking this correctly. hopefully some one knows what in the hell I'm talking about.
Thanks,
Will
http://soundofthatday.com
Old 10-18-2005, 08:00 PM
Default Re: edit the entire file after it\'s been chopped
Just consolidate the track -- you can delete the old track later -- disk space is cheap.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 10-18-2005, 09:25 PM
vocalvoodoo's Avatar
vocalvoodoo vocalvoodoo is offline
Like Rail said, consolidate the track. (alt + shift + 3)
When I have to do this and want to save the regions and keep them intact like you mentioned, I'll duplicate what I have before consolidating and just move the dup down the timeline far enough away from what I'm producing so it doesn't get in the way. Probably better ways to do it, but that works for me.
Old 10-19-2005, 08:58 AM
hzd hzd is offline
You could choose, duplicate playlist. Then you would have the chopped up bits and the consolidated bits alligned timewise, and then just switch playlist if you have to go back to the original stuff. That is also a clever way of keeping the original recorded stuff on one playlist and have a new playlist for each audiosuite you do so you can easily go back to the original.
eMachines M6811
1.25 GB RAM
Internal 5400 RPM 80 Gb
External 7200 RPM 160 Gb Maxtor Firewire
MBOX + 002R
ProTools LE 6.4
Ableton Live 5.2
Old 10-19-2005, 12:11 PM
That's the ticket. right in front of ma face. I should be able to destructively edit the original entire file on a separate playlist and the other playlists will reflect the wave changes. I think.
thanks everyone for your replies. duc rocks.
Will
PT 8 will not play entire Quick Time file... matthewacacia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-17-2009 09:16 PM
Chopped waveforms SofaKing 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-18-2007 11:42 PM
chopped and screwed dat Tips & Tricks 3 07-02-2005 03:18 AM
Chopped audio playback UTS Pro Tools TDM Systems (Mac) 4 03-08-2002 06:09 AM
wish: process entire file.... gugu Pro Tools TDM Systems (Mac) 6 11-26-2000 01:46 PM
