Old 11-06-2013, 05:16 AM
SpinningDisk's Avatar
SpinningDisk SpinningDisk is offline
Default Re: Proper Recording Levels
The video is gone mannnn.
Disk
Sent from my iPhone using Tapatalk.
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey
Alesis Masterlink, Alesis Adat LX20,
, Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon,
Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric.
http://www.johnackermusic.com/
[email protected]
Live and Let Live
Old 11-06-2013, 07:00 AM
Orange is the new yellow.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
Old 11-06-2013, 07:30 AM
JFreak JFreak is online now
Whaaatt....? Yellow is the new red
Old 11-06-2013, 09:01 AM
groundcontrol's Avatar
groundcontrol groundcontrol is offline
AFAIK, 0VU = -18dBFS is a (somewhat ancient by DAW's short history comparison) AES standard dating from pre 24 bit converter days.
The widely used film/broadcast standard of 0VU = -20dBFS is much more in line with present days systems performances.
Can you please send yourself over fiber to go spam some other forum?
Darryl Ramm
Old 11-06-2013, 09:05 AM
Just what I said few posts ago; theoretical 144dB minus practical 120dB (give or take) equals about 20dB headroom
Old 11-06-2013, 09:27 AM
soybalm soybalm is offline
A bit meter can help you with quality levels. If you are recording 16 bit which no one hardly does, it's critical to keep your levels hot as possible without touching red. You can end up with 8 bit audio and less if the level goes down to far. 24 bit makes it less relevant. In theory, 32 bit float is supposed to keep the audio pristine at all levels. So for 24 bit, keep it green and yellow, never red.
bit depth=dynamic range
Dave Cournoyer-guitarist-project studio
Mac Mini late 2012, i7, Sierra
16GB PT10.3.10HD PT12.5.2
Apogee Mini-Me firewire.
Old 11-06-2013, 09:46 AM
If your dynamic range is 18 dB you could be satisfied with 3 bit master. Really. One bit equals roughly 6 dB dynamics. So what you end up with is less important than what you record.
It is the recording phase where you need headroom. Having 24 bit word means 144 dB theoretical dynamics, and knowing the best AD converters can only do about 120 dB it means recording 24 bit makes you not to worry about levels, as soon as they're not too hot.
But once you mix the tracks together, your dynamics is pretty much guaranteed to stay between 24...8 dB so you don't need to think about bitness any longer. You just mix your stuff and mastering engineer does the rest.
This is not rocket science.
Old 11-06-2013, 01:28 PM
YYR123's Avatar
YYR123 YYR123 is offline
Can you imagine when 32 bit A/D D/A converters come out ? $$$$&
Daniel
Old 11-06-2013, 06:19 PM
I actually like that a bit better.
Scott
Core 2 Specs Page
Old 12-11-2013, 04:54 PM
bryced87 bryced87 is offline
I have peak turned on at the bottom of the fader so it's reading -8 to -10. How do you read the meters though? I'm not sure I'm understanding the difference between the numbers on the right and left and of the Faders.
Macbook Pro
Mac OS 10.10.3
Mbox 2,
Pro Tools 11
Question on proper levels LongRoad Tips & Tricks 11 06-14-2009 03:56 AM
rca recording levels/proper interface channel rygar22 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-07-2005 12:21 AM
Recording Levels jawjam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 08-20-2004 01:32 AM
Proper recording/monitoring of vocals MarkH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 26 08-16-2004 11:15 PM
*Recording Levels* mentalmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 08-03-2002 09:10 AM
