003 fire wire chip
Help and advice needed to replace a fire wire chip in a 003
my a quote from a approved avid engineers £450 + 25 postage they told me don’t work down to component level just replace the board' this is after I sent the 003 to them there charging me £25 inspection plus £ 25 return postage to tell me what I all ready new the firewire chip was fried If I can locate the correct chip I'm thinking to have a go and use a dremel cuter and cut the legs close to the chip body the use a low watt iron to remove the legs from the pad I hope using this method it shouldn’t damage the pads if any other advise please reply tom pt 10.3 |
Re: 003 fire wire chip
Even though it's not my day job anymore I still have all the specialized tools to do the job and believe me the local Radio Shack or electronics parts shop will NOT have what you need. It takes a very steady hand and good lighting and good magnification to get things done right. And a tip on the soldering device that's very small. Almost forgot you have to have proper anti0static protection as well. Trust me - it's not a job for the weekend hack. Nobody works down to the component level anymore - it's all board replacement. Part of the reason is just what I outlined above - they just don't have the tools or knowledge to do the job right. The other is it's faster to just put in a new board (assuming they even have one for an old piece of equipment). I'd be more interested on how you fried the firewire chip. Probably a dry winter day and a static zap happened which you probably didn't even feel. Or even hot-plugging something in and that's something I never trusted - connecting computer stuff when it's powered up. |
Thanks for the advice solder wick tape then might as well have ago nothing to lose I'm not paying £500 for a replacement board
Honestly, I'd just buy a used one off eBay:http://www.ebay.com/sch/Audio-MIDI-I...op=15&_nkw=003 or look at changing to another interface completely.
You're looking at spending $500 to repair an old interface, and at the end you will still have an old interface. BTW, did you "hotplug" the firewire connection? I think this is likely the most common cause of FW chipset damage. Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
Solder wick is only part of the situation. You're totally missing the rest of what I wrote. Surface mount solder work isn't easy, even for someone who has the proper tools and training. Give it up; you're going to be wasting your time, and that's assuming you can even get the right chip. You'll have to get the exact replacement piece and they aren't generic like a 6L6 tube.
It's actually a design flaw of the 6pin firewire connector. It can go in slightly crooked and short pins. You can hotplug 4pin and 9pin firewire connectors just fine.
Joel
You need serious skill in Micro-soldering, and a solder station that is designed for this. If I were you, I would either buy a used 003 and move to a newer interface. This is NOT a DIY repair(Do It Yourself)
Eggzackly...
I have done two 003s and a Motu. It's not easy but it can be done.
Brian Campbell "Air mixes better than any console" Bill Porter "Humility is mighty important in this business of listening" Bob Olhsson |
Thru the fire(wire) | MR808 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-01-2003 03:02 PM |
Fire Wire 800 | ndlsd | Pro Tools TDM Systems (Mac) | 12 | 06-11-2003 01:10 AM |
FIRE WIRE | Notefarm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-23-2001 09:39 AM |
Fire wire anyone??? | punky11 | Tips & Tricks | 1 | 11-12-2000 11:31 PM |
Fire Wire? | fender | Storage Subsystems | 1 | 04-14-1999 05:08 PM |
