Sidechain compression without audible key source
How do I set up a compressor and then side chain it to a, for example, kick - without having to have the kick sounding?
If I use a bus as the input to the compressor the bus must be sounding - I can't leave it muted. |
Re: Sidechain compression without audible key source
I've never done this but....
Try setting up a send on the "kick" channel. Rename the send "kick key". Turn the "kick" VOLUME fader all the way down. On the "kick key" SEND fader check the PFL button (Pre Fader Level). Activate side chaining on your desired compressor with the side chain assigned to the corresponding bus, "kick key", you set up on the send of the "kick" track. Set up your compressor with you desired settings and you should see a gain reduction whenever the "kick" channel triggers, no matter the fader level. Hope this helps..... Hope this is right...... |
G EDIT: I didn't see Albee's post, we must have posted and nearly the same time. |
Somehow I've never noticed the PFL button on sends, thanks for that. Also- why do sidechains only accept a mono key input?
Thanks for helping out!
I have typically used the method of creating a send, setting it to pre-fader, and muting the trigger signal. Lately I decided to try the method of setting the output of the kick trigger track to the sidechain bus, but when I do this I notice that my compressor makes clicking noises that don't occur when I use a send rather than the actual output of the track. I have tried the BF76 and the Avid Channel Strip and both yield clicking at the attack.
Shouldn't both methods yield identical results? Why the clicking noise? |
Feed your key buss from a pre-fade send.
Can you please send yourself over fiber to go spam some other forum? Darryl Ramm |
As I described, that's what I do. But i want to know why the other way doesn't work the same! Sheer curiosity.
Bypassing a pan stage changes you're gain structure. Have you tried dropping the level by whatever your pan gain-law is (for ex.: -2.5 dB and -3.5 dB are some typical pan laws).
Just thinking aloud here...
Routing Kick and Bass for Sidechain Compression? | Dingo1 | Tips & Tricks | 6 | 10-13-2007 05:01 AM |
Sidechain Compression | zombie69 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-20-2005 10:42 AM |
Sidechain compression/EQ | BiazedUnfidelz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-30-2005 02:07 PM |
sidechain compression | mbuono | Tips & Tricks | 16 | 11-15-2003 06:26 AM |
192 loss and intermittent connection and then audible clock source | WestPhillySoulzition | Pro Tools TDM Systems (Mac) | 0 | 04-07-2003 09:46 AM |
