  #81
Old 03-18-2019, 07:56 AM
amagras amagras is offline
Default Re: Plugin Alliance insanity
Originally Posted by Muddy-T View Post
Got it a while back Andrei. Lovely piece of kit. It's on 2 bus duty for a lot of the rap stuff I mix. Great on guitars and bass too.
I have not experienced any 'correlation issues', not with 'normal', stereo use anyway.
I tested the 2098 in Jack's M/S scenario and I could reproduce the correlation meter drifting towards and into negative values only when I applied huge boosts to the Side signal without compensating for gain. I believe this is expected behavior, messing with the Side in such a way and all.
Holding on to my voucher for Bassdude's sake!
T
Thanks a lot, I'm on the same boat with the voucher!
amagrasmusic.com
  #82
Old 03-18-2019, 09:33 AM
T
I got the correlation errors in regular L/R. They're expected in M/S. Still sucks.
  #83
Old 03-18-2019, 11:24 AM
Muddy-T's Avatar
Muddy-T Muddy-T is offline
Okay, that's odd. I'm not seeing it.
(For the record, I was referring to the observations you posted in the PA thread on GS a while back which, if I recall correctly, described your experiences with the 2098 in M/S mode.)
T
"Don't look; listen!"
At work; 2013 27" iMac/i5/2.9GHz/8GB, OSX 10.8.5, PT 10.3.6
At home; Custom Made Mac (Hackintosh) i7 (3770 "Ivy Bridge")/3.4GHz/16GB@2400MHz, Samsung SSD 840 EVO 250GB System Drive, Samsung SSD 750 EVO 250GB Audio Drive, OSX 10.10.5, PT 12.8.1
  #84
Old 03-18-2019, 11:26 AM
T
Got it in both modes
  #85
Old 03-18-2019, 11:48 AM
Would it be possible that what you see is crosstalk coming from the random harmonic kajigger they put on it?
amagrasmusic.com
  #86
Old 03-18-2019, 02:51 PM
What are you talking about? There's two controls that possibly fit your description.
  #87
Old 03-18-2019, 03:14 PM
The thing that simulate different channels and has 2 numbers, I can't find a picture with enough resolution to see how it's called
It looks like TnT, TMT...
amagrasmusic.com
  #88
Old 03-18-2019, 09:22 PM
Muddy-T's Avatar
Tolerance Modeling Technology
https://www.pro-tools-expert.com/hom...and-g-plug-ins
T
  #89
Old 03-19-2019, 04:19 AM
This! I don't know if tolerance can cause spill or phase problems but I wonder if Jack turned it off for his test (and if that's even possible). Thank you M!
amagrasmusic.com
  #90
Old 03-19-2019, 04:59 AM
Yes you can turn off TMT. And when I did it didn't seem to make a difference. The only time it solidly stopped messing with the correlation was when I bypassed the whole plugin
As a test I put the Neve, SSL branded E & G strips (that PA sells) on inserts in a PT track in a test session. One audio track which fed one aux track where my metering was. For metering I used both the bx_meter and the freeware Flux Stereo Tool on inserts in the aux. One at a time I enabled each channel strip. Made some eq changes on each strip in different bands. TMT on and TMT off, selected different channels, messed with the v-gain and thd controls. With audio playing, other than level changes the metering showed NO change in correlation - everything stayed positive and the same as the track with no plugins enabled.
BTW today's 'star for one day' is the bx_dyn EQ. I only know about it via GS as I already have it and those that already have a plugin don't get the notification emails when it goes on discount. Still got my $50 voucher - waiting for either Phil's Cascade or Black Box HG2 to drop in price.
HTML code is On
What's up with Plugin Alliance? musicman691 AAX Plug-ins 12 02-28-2018 08:07 PM
Free Distortion Plugin Available from Plugin Alliance Seafoam_Green AAX Plug-ins 14 08-09-2016 09:41 PM
Anyone else have issues with Plugin Alliance Rtas plugin presets? realizment Windows 0 04-01-2015 05:04 AM
Mega plugin deals!! Slate, plugin alliance etc crizdee AAX Plug-ins 3 02-06-2014 11:03 AM
FS - Plugin alliance Roll Buy & Sell 3 07-08-2013 02:28 AM
