#21
Re: Best newer Mac for old PT-MIX system?
- I know lots of G4's with 3 PT Mix cards running well, but they do get hot. On warm days it could become problematic without air-conditioning in your machine room. Btw, inserting a Sonnet card will generate even more heat. Putting your HD's in external storage boxes can help to reduce the heat - connect the S/P DIF Out from your Mbox to the S/P DIF In on your first Mix interface, set your clock in Pro Tools to 'digital' and input to 'Digital SP/DIF'. It will be much better then connecting them analog, with our without API's, unless you would like some colouring from the API's
Marc Schellekens Delta Music Belgium - Dolby Atmos Music Studio https://www.deltamusic.be Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins |
#22
And are we talking about your laptop or your Mix system computer? |
#23
I'm probably going to get flamed for this, but I really think that processor upgrades for G4's are a waste of money.
A dual 1.6 Ghz sonnet is somewhere close to $600, and a G4 with this upgrade is still not going to have anywhere near the amount of processing power for RTAS plugins that the current cheapest mac mini has. If you're using a mix system, forget about RTAS and forget about processor upgrades. You'll gain much more by adding more mix cards to it than by putting an obsolete processor upgrade in. If you really want to run a bunch of VI's, put them on a second computer and use it as a sound module. |
#24
Hi DigiTechSupt,
Sorry, my fault. I was thinking decimals, as per the above posts. The laptop's problem turned out to be that one of the two 1GB RAM chips went bad. Should be rock solid again when I get it back on Monday. Could you verify that the most powerful computer that can run PT 24-MIX would be an MDD Dual 1.42 G4 running OSX 10.3.9? That would be great! Thanks again, Rick. |
#25
Btw, that's also why I have a PT HD 7 Accel with 7 cards in an 7 slot 64 bit expansion chassis connected to a Dual G4 1,25 GHz and have tons of TDM plug-in's (so to record, mix and master I do not have to use RTAS plug-in's at all). When I use the occasional RTAS VI I bounce it to audio as soon as possible and make the RTAS Instrument track inactive to free up the limited CPU power
#26
This is correct, but no OS 9
#27
how does a rig such as you guys are discussing compare to say a newer rig with mbox or something like that? if the op is not going to go up to hd, or the like is it possible for him to be better off with a stronger g5, le, and the latest software?
just curious. |
#28
#29
I would NOT buy anything less than an intel mac for an LE system. The slowest, cheapest intel mac mini is more capable than most G5's as far as processing power for LE is concerned.(a 1.66GHz Core 2 duo mac mini is roughly the same as a dual 2.0GHz G5). The only reason I'd buy a G5 over an intel mac would be if I got a REALLY, REALLY good deal on PCI-X HD cards(The used prices of these are so high it's generally better to just buy the new PCIe ones so you are a little more future proof). And with all the new plugins/new software being optimized for universal binary, I think it's worth the extra money to invest in an intel machine over a ppc. |
#30
IMO an upgraded Digital Audio G4 works best as it's the quietest (mine has a 1.4Ghz OWC 7455 2M L3 clocked back to it's native 1.3Ghz to avoid corrupting the MoBo audio PRAM). It runs one Mix Core and three Mix Farms with no problems regarding heat, and has enough CPU for a couple of mono --> stereo Altiverbs. It runs OSX 10.3.9 with QT 6.5.2 and PT 6.4.1, and Mac OS9.2.2 with PT 5.1.3 no problem. Firewire and USB is slow etc, but other than that no complaints.
My answer to running modern plugz is to have a PC dedicated to running Giga and VST/VSTi's hosted via Cubase, and connected via a RME Digiface --> ADAT Bridges. Additional PC's can be added easily as needed for larger setups too. The ability to have modern soft instruments in tandem with the old Mix+++ system works great for me. Quote:
Newer Avid HD 16X16 compatible with PCI-X TDM system? | Mr. Light | Pro Tools TDM Systems (Mac) | 5 | 06-29-2013 09:48 AM |
So how is Pt 8 On Newer Mac Pro 8 core? | ~Christian~ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-31-2008 07:28 PM |
Are the newer C-24 better? | Imagine | ICON & C|24 | 3 | 04-11-2004 09:11 PM |
Is a SCSI card requirment for MIX system and newer G4 | Valeri | Pro Tools TDM Systems (Mac) | 0 | 06-09-2003 10:06 PM |
Newer 001 user with system questions... | rx2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-05-2003 10:54 PM |
