arturia arp 2600 help
All apologies but Im a MIDI virgin trying to pop my cherry here..... Using The MBOX 2 with the LE 7.0 for windows... I have the Arturia ARP 2600 now that Ive installed all the correct pathing for RTAS I know of (per ARP manual) but now i find myself unable to open in any track type as an insert. The manual tells it like one must open it like any other plug-in and I'll have a window with it ready to go, but it doesnt list on any of the fields optional for the insert. Im just tryin to record whats played on the ARP2600 in a session but Nothing ive tried has worked. Any advice or insight would be enlightening.... also i see where the option to open reason adapted and click and so forth but arturia doesnt show in plug-in instruments. my asio preference in regards to protocol shows asio, but the driver shows none, when in stand alone both show asio.... please help!!!
Re: arturia arp 2600 help
First off, make sure you don't have the demo installed. Delete it in it's entirety if you do. Then re-inatll and make sure you've got it installed as a VST, RTAS and an AU. Sometimes all three of these have to be installed in order for a synth to work.
Apple Mac Pro 2.88 GHz. Intel Xeon Quad core 16 GB RAM Mountain Lion 10.8.5/El Capitan 10.11 Focusrite Saffire Pro 40 Ableton Live 10/Presonus Studio 3 |
done, it still wont pull up in the protools session, it still only show reason, click, and amplitube for interts instruments..... i cant seem to find how here to play and record in a session
The Click plug, is only a mono plug, are you looking in the correct list, i.e., multi-channel plugs list?
Also are you running the Pro Tools Version 7 update for that VI? filosofem
Aaron Mulqueen - 001 HD Native |
ive only tried mono. but with the track on stereo, i tried it and i pulled it up but now no sound, so i guess im half way there......
Try inserting the VI in a Stereo Instrument or Stereo AUX/MIDI track.
filosofem
i see i didnt know i had to change the level that it would start at 0. so problem solved now.... thank you filosofem, my next child will be named after you!!!!!!!!!! thank you x10
P67 i7 2600 vs X58 i7 950 build | clydetower | Windows | 9 | 07-02-2011 03:09 PM |
authorization on Timewarp 2600 | rqstudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 06-30-2008 04:54 PM |
Timewarp 2600 CPU issue | Slowdive90 | Virtual Instruments | 0 | 09-11-2007 02:46 PM |
OT: WangDAT 2600? | jeremyroberts | Pro Tools TDM Systems (Mac) | 1 | 03-12-2003 11:43 AM |
Where can I pick up the AMD 2600+ | Calvin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-28-2002 06:15 PM |
