#21
Re: swapping out my C: drive...?
well, i know i would NOT schedule ANYTHING at 6pm on ANY NIGHT!! personally, i don't schedule my backups, only stating that you could. but i do run my scheduled scans at 4AM EVERY DAY!!! if i'm still workin' at that time it forces me to go to bed!!!
HAPPY NEW YEAR TO ALL!!
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#22
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
#23
Just a quick update on HD Clone (the free version).
I had a 40Gig C: drive in one machine, and using HDClone copied the whole drive to a 80Gig drive in D: then I put the new drive into C:. Boots up fine with everything as it was in a cloned 40Gig partition, and with another 40Gigs blank which I turned into a fresh partition from within XP (My computer/manage/disk management). All software works fine off the clone (including XP) except for a couple, like 3DMax, that run the authorisation pop up - they probably use the ethernet HostID (which I believe is unique to each drive) to check authorisation. It's a great way to increase the size of your drive "0" (C: remains the same size though) or swap out an old one. Disconnect your external drives while you do this. Once you've done the clone take out the old C:, put the new drive in its place, put your old D: drive back in, reconnect your external drive, then boot up. Check it's all working OK, then go into Disk Management, initialise and format the new partition. Viola! Everything will now be as it was with a new partition on Drive 0 which XP will see as F:. In theory you could now put the old C: disk into another PC and it would boot up (provided XP didn't think the hardware had changed too much). If you want to know your own HostID (it took me some research!): Start - Run "CMD" - type in "ipconfig /all" The host ID is the "physical address" with the "-"s removed Donations to Paypal gratefully recieved. And no, I didn't try this on a machine with PTLE installed, but I can't see there'd be a problem - you'd still need your Digi hardware so there's no piracy involved. |
#24
Some (stupid) things that will change your windows product activation ID. enabling or disabling your network card in BIOS, installing a wireless card. And My personal favorite- enabling or disabling hyperthreading. I just swapped a HD onto a replacement board and it was VERY unhappy as far as WPA goes. the boards were the same down to the BIOS revision numbers. At any rate I'm glad to hear it worked. It seems it would be great for cloning your system drive as a backup measure. And thanks for taking the time to search out your old post and check back
#25
My pleasure.
#26
Which tells me why Shake won't load!!! I need to switch networking back on.
#27
Just don't wake the sleeping demon of the dreaded windows activation wizard.... he's in there, Lurking, just waiting to to phone home to Redmond. You got Shake up and running too? You manage to get it running under MAC or Linux? just curious.
#28
Haven't got it going yet. I got a nice nVidia graphics card (which is basically what it wants) and have tried in vain to load Linux into what is an old Compaq machine. Waste of time - the BIOS won't allow it, even after flashing an update etc. Time for a new mobo there I think. However I thought I'd try loading Shake 2.5 (the last version to run on windows) to check that the graphics card is good enough to let it run, but even that's throwing up errors to do with my HostID. I'd switched everything off, but maybe that's where I went wrong and need to switch the network card back on.
If I'd known when I started out... |
#29
Best of luck! Its been my experience that you can basically install Linux on a freaking microwave oven but yeah graphics support is spotty at best. I usually picked the card first or used a version that works with that particular Distro. It does sound like the mother board may have a issue. Linux can be a fun way to refurb a old machine. Trying to install a 3D rendering app like Shake is probably the most difficult thing you could attempt.
#30
I'll keep you posted. Beer time now! |
Swapping Sys Drive to new computer | D Bag | Pro Tools TDM Systems (Mac) | 3 | 10-11-2006 07:05 PM |
Swapping out PC | Soulsanctu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-07-2005 07:12 PM |
Hot swapping the 001 | QuikDraw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-06-2005 02:22 PM |
Swapping Sessions | PRS4LIFE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-06-2003 05:20 AM |
Mac to Pc , swapping a hard drive, heeelp! | ajazzie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 05-14-2003 09:05 PM |
