Upgraded to 10.5.5 and 7.4.2cs2 and now PT wont lauch
I just upgraded my Quad core G5 to Mac OSX 10.5.5 from 10.4.11? in expectation of PT 8 and now I cant launch Pro Tools 7.4.2cs2
It says The application Pro Tools LE 7.4.2 quit unexpectedly. I reinstalled and tried but that didnt work either. I have my 003 powered off to see if it had anything to do but it still does it. Any ideas how to fix it? |
Re: Upgraded to 10.5.5 and 7.4.2cs2 and now PT wont lauch
Yeah, well i unistalled now, and tried to reinstall starting at 7.4 and its doing the same thing, I notice its doing it when its going through the plug ins so Im trying to figure out what needs to be done with there. I looked for dae prefs to trash but i didnt have any? anything else i might have to trash or remove to get this going?
7.4.2 is a stand alone installer, DO NOT install 7.4 first
how did you get to 10.5.5 Combo or Delta updater? (you need to download the combo updater and turn auto software update off)
Going off that note, you did a CLEAN and Complete uninstall before you installed 7.4.2 right? If not that might be ur issue.
MacBook Pro (silver) 2.5 GHz Intel Core 2 Duo - 4 GB RAM - 10.6.6 - PT9 - 003 BLA sig mod Terrarium HD3 Accel on a PowerPC - OS 10.5.7 - PTHD 8.0cs2 (3)192/SYNC IO/CS HEDD192/Studer A27/Neve 48 Ch. VR console |
I used software update to get to 10.5.5. Like I said I think this has something to do with plugins??? I noticed that the waves version I currently have (5.?) isnt supposed to work with 7.4.2, that I would have to upgrade to version 6 waves which will cost me an additional 150 dollars. I'm thinking about going back to 10.4.11 and 7.4 and finish a project I was working on. Oh yeah, did do a clean uninstall.
You def should get updated versions of all your plugs. Though I'm not quite sure if thats whats causing your problem...
When does that msg show up? Is it while PT is trying to initialize plugins? Do you even see the PT windown open?
I get to see the window, and then when its going through the plug ins, thats when it crashes. This sucks that I'm going to have to get the waves update plan in order to be able to use them.
Dang...sure is looking that way. I'd check out waves support before loosing all hope:
http://www.wavesupport.net/SpecialPa...&hidPageType=5 Try putting the waves plugins in the un-used plug folder. See if PT will start up without having to load them up too.
PT 7.4.2 does not lauch | arnikcorp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-04-2010 06:13 AM |
upgraded to 7.4, wont start | dvillage | Pro Tools TDM Systems (Mac) | 30 | 12-18-2008 08:56 AM |
upgraded to 7.3 PT wont open. .screen shows program error | musicmixer04 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 03-25-2007 08:07 AM |
digi 001 wont lauch protools 6.4 | fatality2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-26-2007 08:06 PM |
LE 6.9.2cs won't lauch (Mac OS 10.4.2) | David Penick | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-06-2005 05:04 PM |
