Old 07-13-2010, 11:05 AM
eight16 eight16 is offline
Default White Burst
i updated to 8.0.4 and STILLLLLLLL have this out of control LOUDEST THING EVER white burst noise when audio is playing back and i try and open a plug in. When!!! this destroys my monitors can i hold digi or avid or whatever the hell it is responsible?? This problem just cant seem to be fixed??
Also my system STILL locks up while tracking...the pink record goes across the screen then all of a sudden all the meters freeze and the whole thing locks up. So much for the new update
Old 07-13-2010, 11:14 AM
Dism Dism is offline
Default Re: White Burst
So much for giving us any information on your system.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 07-13-2010, 11:16 AM
im kinda just venting...ive given all my specs on other posts to the tecs or whatever...but i never hear anything back
Old 07-13-2010, 11:23 AM
I noticed.
But some system specs will help those of us who want to help you. It sounds to me like your system is choking. I've heard the noise burst you describe when trying to insert a new plugin while audio is playing and my system is already working hard. This isn't the same as the "white noise bursts" that were an issue in 8.0.3.
What version of OSX are you using? Have you made 100% absolutely sure ALL of your plugins are up to date?
D
Old 07-13-2010, 11:24 AM
DigiTechSupt's Avatar
White noise can have several causes (as evidenced by this thread) and incompatible plug-ins are high on the list.
Can you visit the Help Us Help You thread for details about what we need to know to assist you - a Sandra report, a list of installed plug-in versions, which Avid hardware you're using and details about which troubleshooting steps you've tried are all critical.
Avid Audio Tech Support
Support FAQ
Old 07-14-2010, 03:30 PM
im tryin to search on what a sandra report actually is or how to do it...help please
and the main problem isnt so much the bursts as is the freezing of the whole system...
Old 07-14-2010, 03:57 PM
basslik's Avatar
basslik basslik is offline
Try this bud. YouTube - SiSoft Sandra
MAC PRO 2010 5,1 3.46hex 128ram - HIGH SIERRA - PT 2020.3 / 003 CONSOLE /DIGIMAX FS /PCM90 2CHANNEL SPDIF
Old 07-15-2010, 11:54 AM
Model Name: iMac
Model Identifier: iMac10,1
Processor Name: Intel Core 2 Duo
Processor Speed: 3.06 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 3 MB
Memory: 4 GB
Bus Speed: 1.07 GHz
Boot ROM Version: IM101.00CC.B00
SMC Version (system): 1.52f9
Serial Number (system): W89537T55PC
Hardware UUID: E57E9499-B7B0-5654-BE4B-32EADFD9DBF2
OS 10.6.2
Digi 002r
2 1 terabite OWC harddrive Firewire 800 from comp to 800 of harddrive then 800 - 400 into the 002
Mac OS extended journaled
ILOK connected
USB mouse into the keyboard usb port
Troubeshooting vie done is totally wipe the comp beck to its original with no plugs installed and it still did it
Old 07-15-2010, 12:31 PM
My mistake for asking for a Sandra report - that's only for PC's.
How are those drives formatted? GUID or APM? Did you erase them before putting them into use? If not - back them up and erase them, making sure to use GUID as the partition map scheme. Typically factory formats are a cause for problems like this.
Have you tested with only a single drive and the 002? What about with the internal drive and the 002 and without the FireWire drives attached? Do either of the drives have more than 1 FireWire 400 port?
I'm leaning toward this being a drive issue, given what you've told me.
Have you made sure to put those drives in the privacy panel of Spotlight? Spotlight indexing a drive while you're using Pro Tools could cause noise bursts like what you're describing.
Support FAQ
Old 07-15-2010, 01:00 PM
Ive tried everything your saying here. Running off of just the internal didnt help.
My main issue isnt even the white noise...which happens but not nearly as much as the whole system locking up. During playback or tracking the sound will keep going but all the meters freeze and the spinny ball appears. Then i have to force quit and relaunch...this has been happening since i first installed PT then i reformatted everything and started from scratch and it still does it
White noise burst every 12 seconds. SixChurchStreet macOS 14 02-13-2011 08:11 AM
Burst of White Noise | Assertion Error lunatic Pro Tools TDM Systems (Win) 2 09-27-2009 09:48 PM
White noise burst on a track. Spyrojoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-14-2006 09:45 AM
6.7 White noise burst at end of bounce file contragypsy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 04-21-2005 09:03 AM
Bounce To Disk- White Noise Burst Merle Mayhem 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-09-2002 10:08 AM
