Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 06-27-2014, 01:37 PM
tandem tandem is offline
Default Seperate Feed to headphones?
Is it possible to just send a signal to only the headphone output on the omni?
Old 06-27-2014, 07:09 PM
nst7 nst7 is offline
Default Re: Seperate Feed to headphones?
Yes. That's what the CUE button is for, next to the monitor control. In Protools you will see the option for outputs 9-10, which is the CUE output. You can create sends that go to output 9-10. Whenever the CUE button is pressed (and lit), then that means the headphone jack is receiving output 9-10. When the CUE button is not pressed, then the headphones are mirroring the main monitor output.
Problems with recording mic feed themanontv 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-26-2011 11:01 AM
RSS Feed??? i hear dead people Pro Tools TDM Systems (Mac) 0 06-22-2007 06:33 AM
Feed Back March314 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-20-2007 08:34 PM
LFE feed level to Lt/Rt CCash Post - Surround - Video 3 08-08-2003 08:10 PM
Using Direct Pro Q10s Mic Pre to feed 001? Sushi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-15-2003 03:00 PM
