Old 07-20-2020, 02:52 AM
Julian Wilde Julian Wilde is offline
Default Static edit window
My cursor moves through the tracks on record and playback but the window remains stuck at the start of the track throughout. Help please?
Old 07-20-2020, 03:20 AM
Sonopolis Sonopolis is offline
Default Re: Static edit window
Got to Options-->Scrolling and select the option you like.
Old 07-20-2020, 08:46 AM
That worked. Thank you.
Old 07-28-2020, 08:18 AM
Thanking you in advance for your patience. My next problem with the edit window is that it starts halfway along the pc screen. There's a huge empty gap between the controls and the start of the the recordings.
Old 07-28-2020, 08:43 AM
zoff zoff is offline
I'm not sure if I understand but it sounds like you have Edit Window Scrolling set to Continuous I think you want it set to Page.
macOS Sonoma 14.2 Intel Core i9 MacBook Pro(16,1) 2019, 32 GB RAM Pro Tools Studio 2023.12, RME Babyface Pro
Old 07-28-2020, 11:30 AM
This^^^
Old 07-29-2020, 04:51 AM
That worked. Thanks very much. Next problem (you can tell I'm a musician who never bothered to learn engineering and now regrets it) - where is the master fader in my mix window? I have the recorded tracks but no master slider. I've fiddled with viewing options and just made things worse for myself.
Old 07-29-2020, 05:37 AM
The same way you create any track. Instead of selecting Audio Track from the Track menus, select Master Fader.
Old 07-29-2020, 08:41 AM
JFreak's Avatar
JFreak JFreak is online now
You also need to understand the concept of Master Fader. There is always one for every output in PT mixer, whether internal buss or physical output. Because there are so many, by default Master Faders are hidden. You can make them visible as said, "creating" a Master Fader track for your output.
Janne
Old 07-29-2020, 09:41 AM
But wait! There's MORE You want a STEREO Master track(assuming this is for your main stereo mix) You can also create master tracks for AUX sends(great for a headphone mix that needs a little EQ or a limiter to catch peaks that might be too loud). Groove3 has some of the best tutorials available and everyone I know that has paid to join has found it worth every cent. If you're a poor broke musician, youtube is a decent source(though some tutorials are better than others, if you know what I mean)
Mix Window Freezes but Edit Window works fine. wwicklund 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-10-2022 10:57 AM
MIDI edit issue in Main Edit Window SomeOtherGuy Pro Tools 2020 4 04-02-2020 12:03 AM
Link track selection from edit window to mix window? jaminjamesp Pro Tools 12 7 01-16-2017 05:37 PM
Midi edit window stuck to edit window lvsranch Pro Tools 11 7 04-04-2015 12:42 PM
Cannot change EDIT MODE in edit window Xavior Pro Tools M-Powered (Mac) 2 05-24-2007 12:51 AM
