Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 06-11-2016, 03:08 AM
WinstonJames WinstonJames is offline
Default Focusrite Scarlett 2i2 issues in ProTools 11.3.1
I have been trying for days to work out why Pro Tool 11.3.1 will not work with my Scarlett 2i2 interface.
I keep getting an error message "... please make sure the device is configured properly".
I know the 2i2 is not faulty as it has worked in Pro Tools and will currently playback other sources (iTunes, YouTube, etc).
I've read so many posts about potential solutions and nothing seems to work.
I have set the I/O to defaults, across the board, downloaded the latest Focusrite drivers and re-installed ProTools.
The only thing I can see that looks "suspicious" is this, in the Setup/I/O page:
I would be grateful for any help I can get.
Thank you so much.
Old 06-12-2016, 04:12 PM
Default Re: Focusrite Scarlett 2i2 issues in ProTools 11.3.1
You need to default each of the tabs in the I/O when the focusrite is your set interface.
Then you need to make sure the focusrite is set to a supported buffer size. 64,128,256,512,1024. Then go into the control panel and then the sounds section and be sure the Focusrite is NOT set as the default.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Protools 12.4 Freezes when Idle on Win7 , Focusrite Scarlett 18i20 USB digi98 Windows 4 03-17-2016 05:43 AM
Focusrite Scarlett 6i6 issues bootyt FireWire & USB Audio Interfaces (Mac) 2 12-12-2014 03:03 PM
Focusrite Scarlett 18i20 ProTools crash. BurtonTrucking Third Party Interfaces 7 04-17-2014 11:30 AM
Focusrite Scarlett 2i2 Driver issues in Pro Tools 10 jeremyguy Windows 8 10-02-2013 08:54 AM
Setting up Focusrite Scarlett 2i 2 in protools 10 on Mac jneezy Third Party Interfaces 4 06-21-2013 11:24 PM
