Old 06-13-2012, 08:52 AM
Armando Armando is offline
Default Help, saved Pro Tools session changed/sounds different
Hello,
This happened a few weeks ago and then again last night(same session/different mix). A session mix I was working on and saved the previous day now sounds different. Last time this happened, just quitting the session(not saving) and Pro Tools and restarting took care of the situation. I don't know what the cause was then, I just attributed it to possibly a lock-up issue with a PCM-81 which is connected via AES but I'm not sure about that. Last night, I did two simple trims to the same session, just dropped the entire snare track by .2dB. I did a bounce of the mix to listen to this morning(I didn't bother to check the mix as it was being bounced, my bad) but when I listened to it this morning, not only was the snare level lower but the rhythm guitar tracks were now a few db louder(and not because the snare was lowered).
Anyone have anything like this happen to them and know why?
Hopefully there is a saved version from the previous session in the Saved folder.
Thanks in advance!
Armando
Old 12-18-2012, 03:56 PM
kmoneybts kmoneybts is offline
Default Re: Help, saved Pro Tools session changed/sounds different
I just had a similar problem. A session that I had bounced the song internally (all tracks going through a bus and printing to a stereo track) sound totally different.
Im baffled because this track was bounced, then saved immediately. No hardware inserts, all plugins. It should sound exactly the same but sounds totally different, way quieter, sounds mushy and weird.
Did you figure out what was wrong? I'm starting mixing a record today and need to work from the rgh mixes and this totally puts a monkey wrench in the works....
do you think the bass is taking away from my vocals?
Old 12-19-2012, 02:17 AM
crizdee's Avatar
crizdee crizdee is offline
Originally Posted by Armando View Post
Hello,
Thanks in advance!
Could be your bounce path? Is everything in the session routed to the same output path and is that the path that is set in the bounce to disk page.
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-19-2012, 02:21 AM
crizdee's Avatar
Sounds like a routing issue, something in the session is not routed to the mix bus and therefore not being part of the record to disk.
Maybe something is routed directly to the output and not the mix bus? So would still be heard but not recorded. But would need to know how your session is setup to know for sure.
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-19-2012, 02:57 AM
Stiff Stiff is offline
What crizdee said... And also make sure that any and all automation is catching up.
Daily news & reviews
www.ProToolerBlog.com
Re-opening former TDM session saved in HDX stargazer Pro Tools 10 7 09-30-2013 11:09 AM
Sounds changed when recording Midi Parkman MIDI 1 02-07-2013 12:50 PM
Plugin assignments CHANGED in a saved session dave-G Pro Tools HDX & HD Native Systems (Mac) 8 05-26-2012 09:47 AM
PATCHES not being saved with session ! bennym MIDI 3 12-29-2008 05:04 AM
Can a 5.3 session recorded with HD system be saved as 5.1 session and opened on mix s Ricky Cobble General Discussion 0 02-03-2003 02:10 PM
