Old 06-08-2017, 08:51 PM
Thenewexhibit Thenewexhibit is offline
Default mbox 3 question
Do I need to install mbox 3 drivers on my macbook pro retina (10.10.5; PT 12 vanilla) to use it, or is it like a focusrite scarlette where it's just plug and play?
Thanks!
Mike.
Old 06-08-2017, 09:17 PM
Seafoam_Green's Avatar
Seafoam_Green Seafoam_Green is offline
Default Re: mbox 3 question
you will need to download and install the latest software drivers for the mbox 3
Pro Tools 2018.1 Native * Slate Raven MTi-1 Version 3.3.0 * AVID MBox3 Pro * OSX Sierra 10.12.6 * MAC PRO (late 2013) * 3.5 GHz 6-Core Intel Xeon E5 * 64 GB Ram 1866 MHz DDR * AMD FirePro D300 2048Mb * Lacie LBD 1TB Thunderbolt 2 PCiE * Blackmagic Multidock Thunderbolt2 (Broken !!! - shyte support from Blackmagic Singapore > A-Holes) * Samsung SSD's 850 Pro * WD Black HDD's
Old 06-08-2017, 10:14 PM
Awesome! Thanks!
Old 06-09-2017, 03:01 PM
Ok, coming across a problem here.. I installed the latest drivers, and for some reason, pro tools always says the playback does not support the current playback engine and won't open the session. I came across a thread where it said to switch it to "built in output" and it should be fine.
Now, that works, but then it plays back through my speakers on my computer. So then, I switch it back to the mbox in the playback engine, save, close session, etc. happens, and the same "does not support" message comes up, but then opens the session. I literally have to go through that every single time I want to open any session. Anybody have any ideas as to why I can't just open a session regularly using the mbox mini 3?
Old 06-09-2017, 03:11 PM
john1192 john1192 is offline
here is a little App to toss pro tools preferences .. hopefully this will solve your issue .. since this is a new install ..
https://www.dropbox.com/s/d7szj1osbe...PT%20Prefs.zip
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 06-09-2017, 03:22 PM
Thanks! Is that all that probably needs to be done is to trash pro tools' preferences, then the mbox should work as intended?
Old 06-09-2017, 05:39 PM
NEVERMIND! I'm a complete dummy! It probably would've helped if I downloaded the mbox 3 MINI drivers and NOT the mbox drivers!
Thanks again!
Downgrading MBOX 2 to MBOX mini (Quick question) Mista808 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-09-2011 08:29 PM
quick question - Mbox Mini question - i forget JRup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-18-2009 02:55 PM
mbox micro + mbox 1 + software compatibility question driches 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-15-2008 08:29 PM
Mbox 2 vs Mbox 2 Pro output question dstaskev 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-17-2008 12:46 PM
Mbox 2 vs Mbox 2 Pro (noob question) WeNeverSleep 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-17-2006 12:33 PM
