Old 11-18-2016, 03:42 PM
Dloh31 Dloh31 is offline
Default Any way to disable Input Monitoring for console use in PTHD?
Im not sure if this has been resolved, but for monitoring outside the HD interface (console)Are we able to bypass global input monitoring in Pro Tools HD at all ? In the manual it doesn't really explain on how.
I'm aware of the 'Auto-Input' and 'Input Only' feature. However, as I mentioned, none are of any use when tracking in this particular method. Any assistance will only help myself and others. Thank you
p.s. I'm not sure ticking the PEC/DIRECT option in preference would matter and or fix this..
Old 11-18-2016, 07:05 PM
albee1952 albee1952 is online now
Default Re: Any way to disable Input Monitoring for console use in PTHD?
You can mute the track you are recording to(it still records audio). There's also the freebie Sound Radix Mute-o-matic which can be set to mute when you start playback(record) or to mute when you stop(I use it to kill my talkback mics, but it might serve your needs).
Old 11-19-2016, 09:26 AM
hm interesting. Sounds like something to try definitely.
does it come in tdm as well?
Old 11-19-2016, 11:14 AM
No, but it takes no serious horsepower to run and has no latency on my rig(not sure if yours might be different there). You could insert in the top slot on every track and then ctrl-alt-click to bypass all in a single command(at least that's the Windows command)
Old 11-20-2016, 08:31 AM
tonwurm's Avatar
tonwurm tonwurm is offline
why not disabling "Link Record and Play Faders" in the Preferences (Tab "Operation") and moving down all the faders that are record enabled ?
Mac Pro 2010 - PT10 HD3, PT12 HD, Logic X, DP 7, VEPro, OSX 10.9.5 / 10.12.6
MacBook Pro - Logic X, Mainstage
Old 11-20-2016, 01:21 PM
I see. Id rather not resort to user fixes. This may have to do for now. Was hoping there was something "disable input monitoring while record armed" or something.
Old 11-20-2016, 02:51 PM
What console and how is it connected to/from Pro Tools? There are several ways to accomplish this and maybe one is better than another? Some consoles have tape returns on each strip, so NOT selecting that would only monitor the input, but selecting tape return would then monitor a track from PT. Many will route channel strip insert sends INTO pro Tools, and come OUT of Pro Tools into the strip insert return. But, I have a friend that actually has his console strips all acting as a hardware insert on each track inside PT. Maybe stepping "outside the box" will reveal a better method
Old 11-20-2016, 10:17 PM
The mixer is a mackie mixer 820i going into the line input of the HD Omni along with DB25 channel 3 & 4 I need to know how to disable input monitoring so I can monitor outside the HD Omni's software mixer & Pro Tools DAW.
I shall soon figure it out somehow. I had thought Pro Tools HD had a feature to aim towards those tracking towards the apt mixer user.
Old 11-21-2016, 10:29 AM
Hmmm, whatever works I guess. If I had the Omni, I would not be using the mackie at all. The mic preamps in the Omni are quite good and monitoring directly from PT(thru the Omni) avoids a lot of hassle
Old 11-21-2016, 10:39 AM
29CountsNY's Avatar
29CountsNY 29CountsNY is offline
I use an external mixer for monitoring also and I just mute my outputs in Pro Tools.
I also don't overdub or punch in on the same track. I will create a separate track and overdub on the new track while monitoring the other track then comp the tracks together.
It seems like a major hassle but I can't stand monitoring through Pro Tools and this is the best middle of the road compromise I could come up with.
www.montabonsound.com
www.29counts.com
Pro Tools HD 2019.6 | HD Native PCIe & HD Native Thunderbolt | Lynx Aurora 16 HD | HD I/O | Digi 192 | 2010 Mac Pro 12 Core 3.46ghz | macOS Mojave 10.14.4 | 48 gigs RAM | Tascam DM3200 | Crane Song Avocet II | Antelope Isochrone OCX | Universal Audio Quad & Duo | Waves Mercury + Studio Classics v10 & Abbey Road Collection
Pro Tools HD2 8.1.1 | 2 x PCIe Core Card | 2 x Digi 192 | 2009 Mac Pro Eight Core 2.26ghz
Disable input Monitoring Karl Engel Tips & Tricks 2 01-17-2006 04:40 PM
can I disable input monitoring ? frenchman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-16-2005 07:24 AM
how do i globally disable monitoring? stoogee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-21-2005 08:30 AM
How do I disable Low Latency monitoring Mark Wheaton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-20-2005 11:17 AM
Monitoring delay DISABLE!!! RIO B 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-26-2000 07:38 AM
