Old 03-13-2015, 09:45 PM
soul's Avatar
soul soul is offline
Default Delay Compensation Red
Trying to figure out why my vocal bus is red while the rest is green.
Is it because all of the vocal tracks are on the right side of the mix window? there are many empy drum/bass/guitar tracks to the left of it that are green.
Does Autotune 7 rtas cause this? The vocal tracks have this plug in. the rest dont. Or does any rtas plug have this problem?
The only other plugs are mcdsp eq and compressors (tdm) which are on most tracks.
PD10.3.5 HD Accel 2 Mac OS 10.8.2
Old 03-13-2015, 10:16 PM
soul's Avatar
Default Re: Delay Compensation Red
screenshot here:
Craig F Craig F is offline
delay is twice the HW Buffer + the delay of the process
Red is indecating that it is over the Delay Comp buffer size or a potential feedback loop in routing (feeding a send on a Delay plug Aux back into it's self)
there should be a number on the amount of delay there is on the track
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 03-13-2015, 10:54 PM
soul's Avatar
Thanks Craig, so what do I adjust to resolve this?
This is a mix template Ive been using for years. My workflow has evolved, and a upgrade from PT 8 to 10 since. But Not sure when the red was introduced. Sorry if this seems lazy. My PT attention has waned.
Old 03-13-2015, 11:17 PM
Hardware Buffer is under Hardware Setup
if you can keep the RTAS before DPM plugs should help also, you only have to go through the HW Buffer once not twice
Thank you,
Craig
Old 03-14-2015, 01:56 AM
elicious elicious is offline
i think craig meant to say "dsp" plugs, not "dpm" (which are the rtas versions),
but point taken; make sure you don't have native>dsp>native chains happening.
AT 7 does have a fair amount of delay time; just raise your buffer.
if still red you could always print the vox (although here, AT audio suite is broken with pt10hd)
i'm curious as to why you show red in your gtr bus.
as craig mentioned, you have to watch out for feedback loops,
as well as, side chaining can drive up the delay comp as well.
but we can't see the rest of you mix screen…
and, no, left side, right side don't matter.
hmm. Craig also mentioned buffer changes are under hardware set up; they're under playback engine, but after 11,000 + posts, i'd be woozy, too!
e
ihatetyping
Old 03-14-2015, 09:22 PM
soul's Avatar
thanks!!!
Old 03-15-2015, 03:30 AM
and after work w/o a rig in front of me but anyway
you good or just better?
Thank you,
Craig
Old 03-19-2015, 06:45 PM
soul's Avatar
I just made the Autotune plugs inactive and its all green now!
I should have been able to figure that one out on my own.
thanks for the guidance.
Old 03-22-2015, 12:57 PM
YYR123's Avatar
YYR123 YYR123 is offline
Funny he shouldn't be in the red with 2000
Did I miss something?
Maybe he needs to take his delay comp to the max?
Daniel
help fixing plugin delay and delay compensation disaster prestonhavill macOS 14 12-24-2014 04:35 PM
Delay compensation with backline delay chuck goodwin VENUE Live Sound Systems 3 08-09-2013 08:54 AM
Pro Tools 9 Delay and Delay Compensation on Aux Tracks and Bussing CNSound macOS 1 01-27-2012 12:10 PM
Delay compensation- choice of 'Medium delay'? dtmprod Pro Tools TDM Systems (Mac) 2 05-06-2010 12:00 AM
Delay Compensation - Delay Monitoring when REC Howardk Pro Tools TDM Systems (Mac) 2 06-18-2006 09:59 PM
