Old 03-17-2013, 10:43 AM
gtrm8kr gtrm8kr is offline
Default Rewire to Reaper not working
Hi all. Major steps toward efficiency last week - unparking cores, downloading Reaper for VIs via rewire.
But, PT doesn't see Reaper as a rewire option. Try as I might, I can't get it to happen. I've loaded both the 32 and 64 bit versions of Reaper (loaded the 64 bit version as a last ditch effort). I'm running PT 10.3.4 on Win 7 Pro, and it's been swell so far, except for this issue. I created audio and instrument tracks in PT - no difference. I tried to figure out how to open Reaper in 32 bit mode even, but can't figure out how to do that - and would it even matter if it's the 32 bit version of Reaper?
I've tried matching the sample rate and bit depth - no help there.
Right now I'm using the 60-day trial of Reaper in case that makes a difference (but according to the Reaper site it shouldn't).
Can anyone point me in the right direction here?
Thanks!
PT 12.3 on Win 8.1 Pro, i7-3930k, Sabertooth x79, 16GB G.Skill 2133, Lynx Hilo, Eleven Rack, a "few" guitars...
Old 03-17-2013, 11:19 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Rewire to Reaper not working
AFAIK, you have to use the 32 bit version of Reaper. Not sure exactly what steps you're going through, but you should create an Instrument or Aux Track and insert the Reaper plugin onto that track. Then Reaper will open and be connected via Rewire.
Sounds like maybe you're opening Reaper on its own? Just insert the plugin in Pro Tools and it should open.
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2019.10
Old 03-17-2013, 11:22 AM
DRC Music's Avatar
DRC Music DRC Music is offline
I had issues as well but fixed it by actually installing ReWire here http://www.propellerheads.se/download/updates_rewire/
Then 32bit Reaper... there is a "tick box" under settings in Reaper about using as "ReWire Slave"... Check it
Restart then launch Pro Tools, create instrument track. Insert instrument... it will be listed as a plugin under VI's
• Logic 10.4.6
• MacOS 10.14.5 • Mac mini • 6 Core i7 @ 3.2Ghz • 32GB DDR4 • MOTU 828e
Old 03-17-2013, 11:30 AM
Thanks DRC. That did the trick. [insert sigh of relief here]
Old 03-17-2013, 11:36 AM
DRC Music's Avatar
You are most welcome
• Logic 10.4.6
ReWire and Reaper PatriotsBiker Windows 10 11-08-2012 06:34 AM
ReWire Reaper into Pro Tools not working Legion6789 Pro Tools 9 4 03-27-2011 07:10 AM
Can you rewire Reaper in 7.4?? Dogcode 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-23-2010 07:50 PM
How do I rewire Reaper music Pro Tools TDM Systems (Mac) 3 03-18-2010 02:00 AM
Reaper Rewire dave911 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 03-06-2010 12:00 PM
