Old 08-11-2012, 04:11 PM
xstortionist xstortionist is offline
Default How to: Move Audio Within Seperated Region Only
How can I move only the audio within a seperated region?
I've tried everything and can't figure it out.
Everytime I move the region, it's move it's on the timeline, all I want to do is move the audio within the seperated region where it's currently at on the timeline.
Any ideas? Also, is it possible to automatically create crossfades when you seperate a region? Reaper has both of these options, I just hope pro tools does as well.
Using Pro tools 10 here.
Old 08-11-2012, 04:23 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: How to: Move Audio Within Seperated Region Only
See the Keyboard Shortcuts document, it's one of your best Pro Tools friends.
For moving audio within a region, IIRC, it's Start + Num Pad "+" or "-" for PC and Control + Num Pad "+" or "-" for Mac. Remember, it won't work on whole files. There has to be "unshown" audio for the audio to be able to move.
In vanilla Pro Tools 10 there is no automatic fades generated when a region is cut. That's only in the CPTK or HD. However, there is Batch Fade and this can be set to any value you want. Highlight the region(s) you want fades on and hit Ctrl + F on PC or Command + F on Mac to open the Batch Fades Dialogue. Set the parameters you want - pay particular attention to "Adjust existing fades" and be sure to uncheck this parameter, otherwise any fades you've already applied to the highlighted region(s) will be changed to the setting in the Batch Fades dialogue - and click okay. Once you've set the Batch Fades parameters where you want them, just hightlight the region(s) you want fades on and hit the "F" key in Commands Focus Mode.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 08-11-2012, 04:30 PM
is it possible to move the audio without using the keyboard? I'd like to use the mouse and not the keyboard to move the audio.
Old 08-13-2012, 05:44 PM
Does anyone know how to do this without using the keyboard and only using mouse?
Old 08-13-2012, 06:29 PM
Try SLIP mode(assuming you are in GRID mode right now). Otherwise, maybe we)me anyway) are not really understanding the question. Audio is a region, so the question is a tad confusing.
Old 08-13-2012, 10:27 PM
" For moving audio within a region, IIRC, it's Start + Num Pad "+" or "-" for PC and Control + Num Pad "+" or "-" for Mac. Remember, it won't work on whole files. There has to be "unshown" audio for the audio to be able to move."
This works exactly how I want it to, but I don't want to use the keyboard to move the audio within the region, I want to use my mouse instead.
Old 08-14-2012, 12:19 AM
bacchus40 bacchus40 is offline
thats the only way i've ever moved it myself... never known of any way to do it with a mouse...
kickin' at the darkness 'till it bleeds daYlighT
Old 08-14-2012, 07:44 AM
EGS's Avatar
EGS EGS is offline
In Slip Mode, use the Grabber Tool (with the mouse) and slip the region to wherever you want it. Search the Pro Tools Reference Guide for details.
Desktop: PT 2019.10 / Win 10 / GIGABYTE GA-X58A-UD3R / i7-980X hex @ 3.9GHz / 32GB / Focusrite LS56
Laptop: PT 10 / Win 7 / HP ProBook / i7 quad / 8GB / U-PHORIA UMC1820
Legacy rig (works): PT 5&6 / MAC G4 OS9&OSX / DIGI001
Info/Services link
Old 08-14-2012, 08:20 AM
Stig Eliassen's Avatar
Only way to move the content in a stationary clip, is to nudge the audio within it. Unfortunately, you can't nudge with the mouse.
Old 08-14-2012, 10:31 AM
clausiii's Avatar
clausiii clausiii is offline
Why do you need crossfades when you just seperate regions? in that case there is no need for a fade.
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2019.5
Digidesign Command|8
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Region move problem mccannic Pro Tools 9 2 01-11-2012 10:12 PM
Move region between tracks cananball 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-06-2010 11:56 AM
Move selection only - not region ergalthema 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 05-02-2010 08:08 PM
Move Playhead to end of region? ehausler Tips & Tricks 6 03-17-2010 03:39 AM
Move region with markers? GloryIsSilent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-05-2009 01:40 PM
