So I just built an Intel i7 3.2 ghz machine with 6GB of RAM and installed Windows 7 64bit.
Everything seems to be running smooth on the new machine (haven't installed Pro Tools yet). My old PC has PT7 LE on it and I'm in the middle of two recording projects. If I do the crossgrade to PT9 so that I can install it on the new PC, will I be able to swap the iLok back and forth and still run PT7 on the old PC? |
You can even leave your 7 assets on a separate iLok, and leave both rigs in Operation - I'd spend the extra $30.00 on another iLok for this.
David - MacPro 6,1 Intel Xeon E5 2.7 GHz 12-Core 128 GB 1066 MHz DDR3 - HDX II Sonnet xMacPro Server - 16x16 HD i/o x 6 - PT 2018.10 - OS X 10.14.4 - ProTools Dock / PT Control |
Is your PT 7 enabled via iLok right now? I didn't think an iLok license was needed to run v7. I have seen some people on this forum reporting their PT8 license disappearing from their iLok once it was "replaced" by the PT9 upgrade.
![]() Quote:
So, in theory i shouldn't have any problems. *crosses fingers* |
Sorry, i assumed you were on HD, thinking you had a v7 asset on iLok
v7 LE is Serial Auth, and will keep running - your PT9 Purchase will be authorized via iLok only.
Mac Upgrade Question | Rayvenx2208 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 09-24-2010 09:53 AM |
Upgrade question - can I use mbox2 micro upgrade on 002 system? | spreston | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-22-2009 12:22 PM |
Upgrade to 003 question | Jamtime | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 08-29-2007 03:42 PM |
To upgrade, or not to upgrade? 'Tis the question.. | knewbee | Pro Tools TDM Systems (Mac) | 5 | 03-07-2005 10:09 PM |
to upgrade or not to upgrade, that is the question | paul m | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-06-2004 01:01 PM |
