Old 10-03-2008, 08:32 PM
rbienstock rbienstock is offline
Default OWC Mercury Elite-AL Pro Drives?
Has anyone tried an OWC Mercury Elite-AL Pro drive with a Factory 003? This drive uses RAID 0 to improve performance and OWC says that it is the best drive that they have for audio production and they also state "All Mercury Elite Models are tested and fully suitable for Audio/Video." But Digi says that you can't use RAID drives. Maybe they don't mean RAID 0, though. Other iterations of RAID have a performance hit due to the duplication of data. RAID 0 doesn't duplicate data, but instead increases performance by striping data onto two separate drives, effectively doubling throughput. So will it work?
Old 10-03-2008, 08:46 PM
Default Re: OWC Mercury Elite-AL Pro Drives?
Probably not. When DIGI says they don't support RAID, that means all versions of RAID. Maybe you can reformat as JBOD? Their single(non0RAID) firewire drives work great with Protools.
Old 10-06-2008, 09:33 AM
DigiTechSupt's Avatar
I've got one of these drives at home, so I could probably test it tonite and let you know.
Avid Audio Tech Support
Support FAQ
Old 10-07-2008, 01:22 PM
Sorry, but even a hardware RAID drive won't work for recording in Pro Tools.
Support FAQ
Old 10-07-2008, 04:10 PM
rallycars rallycars is offline
Even if it would work, I would recommend against using it. I have one for my time machine drive and it is quite noticeably loud. It would definitely be an issue if recording in the same room as the computer. I turn it off when using mics. My imac is much quieter than either of my dual drive enclosures. my old maxtor single drive is much quieter. I think it has something to do with the controller that splits the data between the drives because it sounds much more angry than other drives. When my power supply failed i tried to replace it with the single drive unit, but it didn't happen. I would recommend only buying single enclosure drives.
Old 10-07-2008, 04:54 PM
The cool thing about these drive cases is that you get hardware mirroring built in (or other forms of RAID) - good for auto-backups.
Support FAQ
Old 10-08-2008, 05:30 PM
jes's Avatar
jes jes is offline
question for mr rallycars: what interface/external drive combo are you using with the imac? i've always used a tower machine with multiple drive bays inside, and it needs updating, i've been considering the big imacs as i can't afford a mac pro at all. but i use the mbox2 pro, which is firewire and generally has problems with external drives....
http://www.jonathansegel.com
Mac Pro 5,1 3.06ghz 64GB RAM
Macbook Pro 2.8Ghz 16GB RAM
PT 2022.10
UAD-2 Apollo Quad, PCIE and Satellite
OWC Mercury Elite Pro Dual? dr_daw General Discussion 6 02-21-2014 07:50 AM
OWC Mercury Elite Pro drives now with USB 3.0 nst7 Pro Tools 10 0 09-19-2012 07:46 AM
OWC Mercury Elite Pro AL philip morris macOS 6 03-09-2012 07:21 AM
Does OWC Mercury Elite-AL Pro Qx2 work with PT8? 5by5_audio Storage Subsystems 7 06-04-2010 03:15 PM
got one of those mercury elite hard drives but got a probl chazzo03 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-06-2008 06:45 AM
