Old 07-17-2007, 01:18 PM
Table Syrup Records's Avatar
Table Syrup Records Table Syrup Records is offline
Default C24 Main out Volume....
Running with a 002R for now.....
25 pin in (PT Source in) from 002R main out 1&2 (L&R)
25 pin out (Monitor Outs) on 1&2 to Hafler for NS10M's
Seems kinda quiet.
Was much louder straight off the 002R to the Hafler.
Through the 24, I gotta run the 002R wide open and 24 up half way to achieve a reasonable level.
It seems drastic to me...... any takes on this one?
Shorty: Table Syrup Records
Mac Pro 5,1 3.33 GHz Hex, 32GB
EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23"
OSX Sierra
Pro Tools HD 11.2.2
Waves IOS, IOX, STG2412
Extreme Server (x2)
Logic Pro X, DSP Quattro, Final Cut Pro X
Waves Mercury+SSL+AbbeyRoads
Trident S65 with embedded US-2400
Live:
2012 Mac Mini, Dual SSD, i7 2.4, 16GB
Win 10, OSX Sierra
LV1, MRSG
Hardware from above (same gear)
Dual Dell P2418HT Touch Screens
Waves Icon X (x2), M, with Screens
Custom enclosure
Old 07-18-2007, 10:16 PM
Natural Sound Natural Sound is offline
Default Re: C24 Main out Volume....
- Are you running everything Balanced? (all 3 wires)
- Make sure that nothing is shorted (all it takes is a stray strand and you'll lose 6db)
- If all that checks out, you can raise the C24 to about 2/3 up. I'm pretty sure that's the nominal setting. (there should be a little 0 at that point on the board. So if you're running it now at about 1/2 way your probably down about 6 to 10db.
Thomas Anthony
Natural Sound
Old 07-19-2007, 07:37 AM
Everything balanced.
Thanx for the feedback though. Everything checks out. No shorts.
I guess maybe that's just how it is...
Kinda makes sense really- I'm used to a master fader and an monitor knob
(The knob was infinately variable - EVENLY all the way up or down)
The knob on the 24 is set up like a fader- more attenuation at the bottom than my old knob....
Just a little different.
THANX!!
OSX Sierra
Pro Tools HD 11.2.2
Extreme Server (x2)
Live:
Win 10, OSX Sierra
LV1, MRSG
Custom enclosure
Fast Track c400 low volume cut-off by main knob MikeyC FireWire and USB Audio Interfaces (Mac) 7 04-09-2013 04:41 PM
Enabling Trim Automation for Main Volume only marvschlom ICON & C|24 2 03-07-2013 10:56 AM
Main volume knob...is it just like the 002R? Gothboy ICON & C|24 1 05-09-2010 08:29 PM
Main volume monitor? LarsKatz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-30-2010 11:19 PM
Main Volume Level Kipsey Tips & Tricks 0 05-01-2003 07:38 PM
