I can get one of this ( http://www.thomann.de/se/boss_fv500l.htm ) at a good price but how do I find out if the expression function work with my Eleven Rack ?
Any help is greatly appreciated ! Thanks ! |
![]() Quote:
The expression pedal behavior of the 500L and 500H should be the same so just choose which model you want for use as a volume pedal (if you care at all about that). Darryl |
![]() Quote:
I use the FV 500 H and it works great!
Guitars: Schecter C-1 Blackjack ABSN, Ibanez RGA 121 Amp: ENGL Ritchie Blackmore Effects: TC G Major 2 Awesome: Eleven Rack (with EXRP)+ M-Audio Bx8a's |
Just to let you know, I have the FV-500-L and it works well with the Eleven Rack.
Thanks everybody for your input !
I bought the BOSS FV-500-L and has already replaced it for a new unit once !
I only use the expression jack and after using it for a couple of days I noticed it became very glitchy and did not have a smooth travel especially on wah pedal. I replaced it with a new pedal and now that has the same issue ![]()
Choose AVID if you really want to be sincerely Screwed ! |
![]() Quote:
Have you abandoned the Boss pedals for expression with the 11R? I sold my EV-5 a few years ago but am thinking about getting e new one, but now I'm starting to get a little worried about the quality even though the one I hade felt good even though it was plastic. I didn't use it very much so I don't really know how the pedal will stand the test of time but would like to have something small like that to use with the wah-wah on the 11R. |
![]() Quote:
I don't use mine on a daily basis but whenever I do have to work it a bit to have a smooth transition between heel and toe. The pots clearly aren't top quality ! They must have had a really bad batch but it's now about 18 months since I first bought the first one. However - Next time I am going to think one extra time before I put my money on a BOSS pedal !
Thanks for the reply.
![]() Wow, 4 times! ![]() Guess those plastic Boss pedals are out of the question then...metal it is. |
Roland expression pedal not functioning properly with eleven rack | lbar11 | Eleven Rack | 9 | 03-16-2017 11:35 AM |
Using Ernie Ball Volume Pedal as WAH Expression on Eleven. ? Need your help fast! | awritersparadise | Eleven Rack | 18 | 11-15-2012 07:48 PM |
Eleven Rack Expression Pedal | brianiac5150 | Eleven Rack | 13 | 12-10-2011 06:33 AM |
11 Rack & Expression Pedal as Wah and Multiple EFX | VOX59 | Eleven Rack | 10 | 11-20-2011 01:43 PM |
Exp pedal w/ Eleven Rack and 003 rack weirdness. | decayd | Eleven Rack | 1 | 08-07-2011 04:56 PM |
