Old 01-18-2018, 12:05 AM
RogerPaolo RogerPaolo is offline
Default AVB volume control in direct out mode
I was playing with the S3 audio I/O settings, and have 2 questions about this.
1. is it possible to control AVB volume to the Main output? turning the rotary encoder under AVB1-2 OLED doesn't change the level of the signal from my daw. ( I understand I can control this from the software with the MAIN fader. Just wondering if this can be controlled from the hardware mixer)
2. In the manual it says:
"Zero-Latency Monitoring While recording through S3, use Direct Out mode to route S3 input(s) to your main monitor outputs. In Pro Tools, mute the track you are recording to. Use the S3 encoder for Direct Out Level as a mix knob to balance input level with your main mix. This is similar to the Mix Knob on Mbox and other similar audio interfaces."
but actually, when Shift pressing the desired input, the rotary encoder controls input gain (as it does when not Shift pressed), and not only the amount of signal sent to Direct Out. So raising this level also raises the total signal (also that sent sent to the DAW), potentially resulting in clipping.
Old 01-22-2018, 12:41 AM
Default Re: AVB volume control in direct out mode
regarding point 1. of my question: I found in a video that turning the 14th encoder does not influence AVB input level but the amount of gain reduction when pressing the DIM button on the 15th and 16th encoder.... so only question 2. remains open....
Headphone volume in record mode bariguitar Pro Tools 11 0 12-03-2014 04:22 PM
Digi 003 Control Surface Mackie Control Mode ctmusicman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-23-2008 07:23 PM
Low volume in Monitor mode with new computer ON... Just_Joe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-21-2004 08:35 PM
PT6 allows audio to be deleted in volume mode jimlongo Pro Tools TDM Systems (Mac) 1 01-15-2004 06:57 AM
PTIII in direct i/o mode in windows ??? teddy-m Pro Tools TDM Systems (Win) 0 08-25-2002 06:47 PM
