Old 04-29-2006, 12:12 PM
Ghieri Ghieri is offline
Default How Do you Connect The Control 24 to 4 192\'s?
How Do you Connect The Control 24 to 4 192 audio interfaces? The instructions are not very clear. I have the control 24 cable kit which are DB25 to XLR or 1/4 connections. I think that I need DB25 to DB25 to connect to the interfaces but i am not sure, but even then it is not clear on what out/ins to connect to!!!!
Old 04-29-2006, 03:56 PM
Kroger Kroger is offline
Default Re: How Do you Connect The Control 24 to 4 192\'s?
Well it all depends on your setup. Are you going thru a patchbay or....?
If you want to connect the C24 directly to your interfaces ytou can use the DB25 -> DB 25 cables. Since there is only 16 preamps you will connect the 1-8 to your first interface and 9-16 to your second interface.
These 2 are just below the XLR inputs on the back of your C24 Labeled "Line Out"
The output of the first interface should be connected to the monitor input of your C24.
This is on the left side of the back of the C24 labeled "Pro Tools monitor"
You can connect your speakers to the speaker out and if you want to connect some cd players or other directly to the monitoring section you use the "external sources" input.
All this btw is explained in the guide. You can find it here:
http://akwww.digidesign.com/support/...ol24_Guide.pdf
Last but not least: Welcome to the forum! Enjoy your stay
Old 04-30-2006, 11:23 AM
Yeah I seen that and tried to go off the guide but it was not very clear to me @ all, but thanks your input helped alot.
How to connect Control 24 to Macbook Pro jbmoonshine Third Party Interfaces 2 05-06-2013 08:28 AM
Can not connect control 24 pro tools 6.9 Isengard ent ICON & C|24 4 02-22-2011 04:35 PM
trying to connect mid USB control surface... cinetj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-07-2010 01:38 PM
1 x HD2 2 x 192's 1 x Control 24 1 and a patchbay Jac Shalare Pro Tools TDM Systems (Mac) 1 07-12-2004 07:47 AM
connect control 24 to my MAC cookie ICON & C|24 3 12-30-2003 07:10 PM
