PODxt via USB into PT 6.9.2
I'm trying to set up the PODxt via USB into my 002 Rack LE 6.9.2. I'm new to Mac. I have a G5 running "Tiger" 10.4 I thought I'd be able to open the POD as 2 tracks unto themselves. Ex: Am using 16 tracks, would like to run POD in tracks 17/18, as USB in. I can't get it to open as a plugin. either. I thought I'd be able to. Suggestions?
Re: PODxt via USB into PT 6.9.2
Nope, won't work. Protools will not record from USB from a non-Protools interface.
What you can do is connect your POD to your 002R using the 1/4" balanced outputs on the POD into two of the 1/4" balanced inputs on the 002R. Set them up as a stereo track in Protools, and you'll have your connection into Protools. Unless the POD software is able to work via rewire, then you may be able to do what you want.
Justice C. Bigler www.justicebigler.com Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools Ultimate 2023.6 / HD|Native-TB 2018 MacBook Pro: six-core i9, 32GB, 1TB, Monterey / Protools Studio 2023.6, / DVS / DAR, L-ISA Studio Home/mobile: Focusrite Red 8Pre+HD32R / Clarett 4Pre Road/hotel: Roland OctaCaputre / Apogee One |
connect the POD via SPDIF to the 002r.
Then you can record digitally into PT, and reamp also (use as PlugIn).
ReRecording Mixer & Venue D-Show Live Sound & Recording Engineer www.audio-machinery.com |
Thanks for the help. I thought along the same lines, but, the POD book is not very clear. Consensus is to use the S/PDIF, but, to also search the Re-Wire route, too. Again, thanks!
Thank you, too!
On the POD XT (the small podlike apparatus) there's no s/pdif connection unfortunatelly... s/pdif can be a lightpipeconnection or as in most cases a single cinch connection (or double for in ánd out). So the simple audioconnection will have to do. This is how I record our guitarplayer and it works just fine. Good luck on recording! Greetings earthling! |
Using podxt as a plug-in | dicer13 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-27-2005 10:46 AM |
PODxt for Pro Tools | powerjoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-27-2005 06:56 PM |
anyone using the podxt? | shynomi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 02-09-2005 05:48 AM |
Difference between PODxt and PODxt pro...other than $300!! | pedrohead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-09-2003 06:28 PM |
Anyone tried a PODxt yet? | KamaSutra77 | General Discussion | 1 | 11-07-2002 09:42 PM |
