Simple editing question on building a click track
I want to set up a click track using a sidestick sample. I put it in grid mode, then set my sample region to bar 1. I then use the "Repeat" command, and the new regions all line up nose to tail instead of on the grid lines. Am I missing something, or do I have to manually slide them all into place?
Re: Simple editing question on building a click track
I do the same thing. Be sure when you copy the measure, that you copy the free space also - that is - don't copy and paste just the soundbite, copy and paste the entire measurre.
This way when you repeat, your click will be spaced by measures and not back to back. I hope this helps. Good luck! |
If your region is longer than 1 bar, then trim it in grid mode using the trim tool to be exactly 1 bar...then repeat or duplicate as many as you want.
R |
Leon,
That was it. Thanks. Rob, it's usually shorter. |
Glad to have helped!
Gotta love this place! [img]images/icons/grin.gif[/img] |
Click Track - so simple I'm missing something | rdelorenzo | Windows | 5 | 10-22-2012 08:07 PM |
Help: simple editing question | Budger | General Discussion | 3 | 12-29-2008 09:20 AM |
Please help, simple editing question. | slowburn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 03-15-2007 12:10 PM |
SImple editing question | nyquistuk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-16-2006 03:34 PM |
simple question: CAN'T HEAR CLICK TRACK | novasonic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 10-13-2002 06:51 PM |
