#31
Re: iOS monitor control for MTRX
Ah great! I did update the firmware/DADman the other day, but have only done a quick regression test with the app.
BTW the coming version supports Bluetooth input devices, so you can for example assign a foot switch to the External key.
https://lukehoward.com/ |
#32
Nice Job Luke!
After reading this I am writing some s/w for the TMC-1 to emulate the Mom, it can also talk with both the PC and MTRX/NTP/DAD which will allow me to incorporate meters. One suggestion for you, why not include the External GPI as an extra switch on your interface. Kind Rgds Colin |
#33
It's a good idea about the External GPI, actually to be honest I just forgot about it initially – however one reason is that there's no visual feedback associated with the External key in the protocol, and this may have some UX implications. I need to think about it some more. It will be mapped to the arrow key (I forget which right now) in the next version. Re: meters, I'm sure you've figured this out but – unfortunately the MOM protocol won't give you meter information below -40dB and only in 0.5dB steps. And you have to jump through some hoops to interpolate the actual dB value from the LED colour states. But, one deals with the cards as they are laid!
#34
#35
I'd be interested in adding metering to the app, although unless there's a way to have DADman proxy that over the MOM protocol, I'd rather not have to pair the app directly with the MTRX/AX32. Still, I might just have a peek with Wireshark now... :)
#36
Luke, thought you'd get a kick out of this "client case" posted on Avid's website
https://www.avid.com/customer-storie...ent=1544451630 let me direct you to near the end for the pull quote: Quote:
#37
Ah, awesome! Glad someone is finding my first attempt at iOS programming useful There's still an issue with DADman not dealing gracefully with MOMs that come and go from the network. Hopefully they will fix it although arguably it's not in their interest if they're hoping to sell hardware controllers!
#38
been following this thread with interest, since we are about to order an MTRX and DAD MOM controller. The iOS app looks good, will try it for sure when gear arrives. Thanks to the developer Meanwhile, if somebody could provide some help on the following would be greatly appreciated: I noticed the the DAD MOM has a GPI input, but the MOM user manual is scarce on info about it. It only says that it´s a mini jack, can be used for a footswitch and that functions can be programmed on the DADMan/Pro Mon. We would like to use the GPI to remotely activate the Talkback switch from the producer position which will not be within reach of the unit. But instead of a footswitch, we would like to use a tabletop switch. Does anybody has experience on building such a circuit? Would a SPST momentary switch do the job? Is the mini jack needed a TRS or just hot and shield? Any advice from MTRX and MOM users? Many thanks.
Regards, Paulo M MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura Protools Studio 2024.3 |
#39
SPST momentary should work fine. The GPI Input 3.5 mm jack should be tip and shield but either will work. Just don’t solder the ring if using TRS.
You’ll know it’s working without the switch in place if you have it plugged into the mom and touch the bare wires together at the other end and the TB triggers. |
#40
Do you know if is there any way the external switch can replicate the latch/momentary behaviour of the TB switch on the MOM by short or long press? Or it just activates Latch mode? Can you tell me the options that are available on the Dadman/Promon to configure the GPI? Sorry for so many questions and once again thanks for the help!
Does the Monitor Control Room knob on the Artist Control do anything? | Focuret | Artist Series | 34 | 01-29-2024 03:14 PM |
PT Dock / MTRX Control | remotedude | Avid S1, S3, Dock and Control App | 11 | 12-16-2018 07:40 PM |
Monitor Knob - Cut Assignment like XMON but now for MTRX | innenhofstudios | Avid S4/S6 | 10 | 05-17-2018 03:23 AM |
MTRX | antonis | Post - Surround - Video | 2 | 10-26-2016 12:31 AM |
Artict Control Monitor/Control Room Knob & HD Omni | DAWgEAR | Artist Series | 4 | 07-07-2014 01:56 PM |
